Comware
How to display 3COM 4210 serial number ?
  • 1.  How to display 3COM 4210 serial number ?
    Posted Apr 02, 2015 02:18 AM
    Hello
    I have 3COM 4210 , 3CR17333-91 at remote site, how can I get serial number of that switch through CLI ?
    Regards
    P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to Comware-Based. - Hp Forum Moderator
    #switch
    #3COM4210
    #CLI
    #switchinformation
  • 2.  RE: How to display 3COM 4210 serial number ?
    Posted Apr 07, 2015 04:18 AM
    Hi Asim_Ali,
    I think the 4210 runs comware 3.
    try the command : display device
    or maybe you can get it using snmp.
    Try OIDs
    HH3C-ENTITY-EXT-MIB::hh3cEntityExtManuSerialNum
    or
    ENTITY-MIB::entPhysicalSerialNum
    depending on which MIBs the unit supports.
    Regards
