Cloud Managed Networks
  • 1.  How to factory reset Aruba UXI sensor?
    Posted Oct 14, 2020 05:48 AM
    Hello, i would like to ask, how do you factory reset an Aruba UXI sensor? Specifically the ASIN0100 model.
    Thank you.
  • 2.  RE: How to factory reset Aruba UXI sensor?
    Posted Oct 14, 2020 05:38 PM
    Why do you need a factory reset of the sensor? You can remove a sensor and add it again to the cloud portal. For any questions you can use the chat feature in the portal.
  • 3.  RE: How to factory reset Aruba UXI sensor?
    Posted Oct 14, 2020 06:26 PM
    I want to reset the configuration (IP, ssid, etc) because it will be used for PoC at another customer.
  • 4.  RE: How to factory reset Aruba UXI sensor?
    Posted Oct 14, 2020 06:51 PM
    Understood! Just remove the sensor and add it again with another group, ssid and wires network. Afterwards reboot physical the sensor and it comes online in a clean group config.
  • 5.  RE: How to factory reset Aruba UXI sensor?
    Posted Oct 20, 2020 01:42 AM
    Do i have to connect the sensor via ethernet to do that? Or can i use SSID only to connect the sensor to the internet?
  • 6.  RE: How to factory reset Aruba UXI sensor?
    Posted Oct 20, 2020 05:32 AM
    Most Sensors are buyed with a 4g cellular subscription. When the sensor registered in the cloudporal and is licences it can be managed without an active ssid or ethernet cable.
    If you don't have a cellular subscription plug-in an ethernet cable to get DHCP and reach the internet.
