Again, I don't remember that I've seen these before... I know for the online Help there is an option in some products, which if enabled, adds links to the items in the WebUI and provide additional information.
Hopefully someone else has seen these and know a way to turn those off? Or TAC.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: May 07, 2025 06:31 AM
Subject: How to get rid of !-icons in old Central UI??
Hi Herman,
Those are new Central "how to do this easier" so no real issue (except icons blocks links every now and then..)
Original Message:
Sent: 5/7/2025 4:53:00 AM
Subject: RE: How to get rid of !-icons in old Central UI??
I don't remember having seen those before. There may be something serious wrong, like expired subscriptions or blocked connectivity from your devices to Central.
Do you know why these are there? Do they show something when you 'hover over them'?
If you don't have a clue, please work with TAC.
Original Message:
Sent: May 06, 2025 11:15 AM
These exclamation marks are really annoying... How can I remove them?
"Don't show this again" button does not do what it promises and cannot find any other way to disable icons.
Good information but should be located behind top right corners question mark.
Jori Luoto
AV-IT Specialist
