Internet of Things (IoT) and Industrial IoT (IIoT)
  • 1.  How-to IoT transport telemetry-https -> Splunk HEC?
    Posted Oct 02, 2023 03:18 AM
    Has anyone successfully been able to connect and send to the Splunk http event collector (HEC) using telemetry-https ? I know that web socket is preferred but on-prem Splunk Enterprise does not support it and a third party add-on is not installing correctly (a different support issue).
    I am able to connect and write to the Splunk index using CLI cURL
    POST./services/collector/raw.HTTP/1.1..Host:.172.20.0.10:8088..User-Agent:.curl/8.0.1..Accept:.*/*..Authorization:.Splunk.c40346d6-02f3-4472-aafa-208406847242..Content-Length:.45..Content-Type:.application/x-www-form-urlencoded....{"event":."Event19",.."sourcetype":."manual"}
    but it fails from the IoT transport
    POST./services/collector/raw.HTTP/1.1..Host:.172.20.0.10:8088..Content-Type:.application/json..Authorization:.Bearer.c40346d6-02f3-4472-aafa-208406847242..Accept:.application/json..Content-Length:.2336..Expect:.100-continue....
    I think the keyword "Bearer" may be the issue. Splunk HEC requires "Splunk" before the token, but this fails as well
    Authorization:.Bearer.Splunk.c40346d6-02f3-4472-aafa-208406847242
    I have tried entering the token in the URL but that is not allowed by Splunk on-prem, as well as many other tries with various syntax. Hoping someone has set this up and will share the how-to thank you, Matthew
  • 2.  RE: How-to IoT transport telemetry-https -> Splunk HEC?
    Posted Oct 05, 2023 09:45 AM
    Your server needs to support the Aruba telemetry-https format, which does use a Bearer token for it's authorization. Does your Splunk server understand telemetry-https?? If so, it should accept the Bearer token. And if you were to go beyond the authentication token, it may be that the messages are not understood.
    Probably best to work with Splunk support on this one, as on the Aruba side it is what it is and you can't change too much.
  • 3.  RE: How-to IoT transport telemetry-https -> Splunk HEC?
    Posted Oct 11, 2023 08:56 PM
    Thank you for the response @Herman Robers I will work with Splunk support.
