Comware
  • 1.  How to IRF Model FF5700-40XG-2QSFP+?
    Posted Mar 31, 2020 10:45 PM
    Questions
    The current software version is Switch-2422p01
    When configuring two switches as irf
    Is there a supported / unsupported os version?
    Is it configurable to the current version?
  • 2.  RE: How to IRF Model FF5700-40XG-2QSFP+?
    Posted Mar 31, 2020 11:26 PM
    Yes you can configure IRF on Release 2422P01  also you can configure IRF on all firmware versions .
    Refer below link for IRF configuration guide for software release 2422P01 and later
    https://support.hpe.com/hpesc/public/docDisplay?docId=c04406882
