Original Message:
Sent: Sep 06, 2024 03:42 AM
Subject: How to know if port 4500 is open in Wan access
Thanks for the input, but the problem is that the tunnels are not established, and I would like to check if the cause is that port 4500 is not open.
When performing a "show datapath session" it shows nothing on port 4500
Original Message:
Sent: Sep 05, 2024 11:39 AM
You could run the 'show datapath session' an see if there is traffic arriving on port 4500 (or if the controller is attempting to send traffic). For an established tunnel you should see two entries per tunnel (example below is tunnel between 192.168.31.33 and both 192.168.36.8 and.11):
192.168.31.33 192.168.36.8 17 4500 4500 0 /0 0 0 82 0/0/1 1bc7 0 0 FY 1 16421/0 /0 1192.168.31.33 192.168.36.11 17 4500 4500 0 /0 0 0 93 0/0/1 1c7a 0 0 FY 1 16421/0 /0 1192.168.36.11 192.168.31.33 17 4500 4500 0 /0 0 48 0 0/0/1 1c7a 132777 28720444 FC 1 16421/0 /0 80040192.168.36.8 192.168.31.33 17 4500 4500 0 /0 0 40 0 0/0/1 1bc7 134951 29323504 FC 1 16421/0 /0 80040
Original Message:
Sent: Sep 03, 2024 03:14 AM
I have a BGW and a VPNC installed, but the tunnel is not established between them. I am trying to see if from one of the Gateways I can check if port 4500 is open when establishing the tunnel, but I do not have access to the INET routers, so I would like to know if there is any way to check it from the Gateway, something similar to a #telnet ip_destination port 4500.
