How to make a difference between smartphonesand tablets?
  • 1.  How to make a difference between smartphonesand tablets?
    Posted Oct 14, 2014 09:48 AM
    I was looking on the profiler and it divide it in smartdevice and computer or unkown
    The problem is that how do i differenciate between smartphone and a tablet?
    The tablets should be allowed but smarphones should not be allowed.  Is this possible for the clearpass to differenciate if its a tablet or if its a smarphone???
    Cheers
    Carlos
  • 2.  RE: How to make a difference between smartphonesand tablets?
    Posted Oct 14, 2014 09:49 AM
    You would either need to rely on "Device Name" or use the fingerprint data from the controller.
    For the fingerprint data, see my post below. You can use similar logic to target tablets.
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Tip-Using-IF-MAP-fingerprints-to-identify-legacy-devices/m-p/156396/highlight/true#M11549
