Comware
  • 1.  How to setting VLAN on 1910-48G Switch (JE009A)
    Posted Jun 08, 2012 12:18 AM
    HELO all,
    i really need help on this problem..   i need setting vlan becouse my pc will be over more than 200 ++ include server.
    my question is :
    -how to setting vlan ?
    -how to make block A and block B can see in network and share file .
    -how to make  block A and Block B  can access  server A,B,C,D
    i attach my network diagram
    P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to Web and Unmanaged. - HP Forums Moderator
    #1910-48GSwitch(JE009A)VLANHELP
    #VLAN
  • 2.  RE: How to setting VLAN on 1910-48G Switch (JE009A)
    Posted Jun 08, 2012 04:02 AM
    How do you want to split your network ?
    Block A is a vlan and block B another ?
    Is there a vlan for the servers ? the printers ? others ?
    In your diagram Block A use the same subnet as Servers, is it normal for you ?
    With this switches you must create static routes to allow a network to connect to another.
  • 3.  RE: How to setting VLAN on 1910-48G Switch (JE009A)
    Posted Jun 10, 2012 09:27 PM
     - i wan 192.168.0.** and 192.168.1.** can linked each other (can see in network share )
    Block A  and B  have network printer
     ya all printer n server using same subnet
    other forum give suggestion  to change subnet to 255.255.254.0 then both ip can see each other .. its that true ?
    have manual guide for this switch ?
