Comware
  • 1.  How to setup HP A5500 Layer Three Switch vlan and routing
    Posted Oct 29, 2014 11:24 PM
    Hp Core switch A5500 how to setup vlan and state routing,Please advise me
    Attachment(s)
    pdf
    Visio-VN VLAN.pdf   703 B 1 version
  • 2.  RE: How to setup HP A5500 Layer Three Switch vlan and routing
    Posted Oct 30, 2014 01:50 AM
    Create two VLANs, 100 & 150.
    Check your PCs on the network - you need to find out what the Default Gateway is for PCs on each subnet.
    Configure the default gateway IP address for 192.168.78.0/24 network as the IP address on the VLAN100 interface.
    Configure the default gateway IP address for 192.168.76.0/24 network as the IP address on the VLAN150 interface.
    Find the switchport that your "Red" network is patched to, and configure that switchport to be an Access port on VLAN 100.
    Find the switchport that your "Blue/Black" network is patched to, and configure that switchport to be an Access port on VLAN 150.
  • 3.  RE: How to setup HP A5500 Layer Three Switch vlan and routing
    Posted Oct 30, 2014 02:36 AM
    I need  to create 2 VLAN, what switch to create VLAN and ALL VLan PC need to access internet, please find attachment and advise me, many thanks
    VLan :73 --> 100
    Gateway: 192.168.73.254
    VLan: 75 --> 150
    Gateway: 192.168.75.254
  • 4.  RE: How to setup HP A5500 Layer Three Switch vlan and routing
    Posted Oct 30, 2014 10:46 PM
    Ah, so after creating them, you need to trunk both VLANs from the 5500 to the 1910.
    Then create both VLANs on the 1910 and assign each VLAN as an untagged VLAN on an Access port to the correct PC.
    You will need to create a route on the 5500 pointing at the FW.
