Comware
  • 1.  How to use auto-edge-port?
    Posted Sep 18, 2008 09:25 AM
    In the newer Procurve software releases two new commands have been introduced for Spanning Tree, the auto-edge-port and admin-edge-port.
    If I understand it correctly admin-edge-port means that I declare a port as "edge", and it would always go directly to forwarding.
    And the auto-edge-port will try to detect if the port if a edge or switch-to-switch port. This seems to be the default for all ports.
    My question is, do I need to change this settings for the links to other switches?
    With the old "edge-port" command HP recommended that you did not use that on switch-to-switch ports, as it would increase the risk for temporary loops. What about the new command?
  • 2.  RE: How to use auto-edge-port?
    Posted Sep 18, 2008 07:15 PM
    Hi Ric,
    I have not seen customers modifying these settings in general. Most of the time, the auto-edge has worked well at identifying the port as an edge port or a non-edge port and passes spanning-tree BPDU's appropriately.
    The two reasons I can think of that this is important is that you do not want topology change notifications being sent through the network when an edge port goes online/offline. Second, you do want switch to switch links passing BPDU's so that the spanning-tree path is agreed upon in the network and a switch/vlan is not orphaned in the network.
    Hope that helps.
    Jarret
  • 3.  RE: How to use auto-edge-port?
    Posted Sep 20, 2008 02:46 AM
    Hello RicN,
    I get this hint from internet,
    "Spanning-tree auto-edge-port: Supports the automatic identification of edge ports. The
    port will look for BPDUs for 3 seconds; if there are none it begins forwarding packets. See
    the chapter titled â Multiple Instance Spanning Tree Operationâ in the Advanced Traffic
    Management Guide for your switch."
    You can get the the0 "Advanced Traffic Management Guide" from internet â in case you didn't have already- and read more about it
    Hope it helps & points are welcomed
    Jan
