Network Management
  • 1.  How to view installed components through imc web portal
    Posted Apr 16, 2020 04:45 PM
    Does anyone know if and how it is possible in IMC 7.3 E0705 to view deployed components through imc web portal as on attached screen? What modules must be installed?
  • 2.  RE: How to view installed components through imc web portal
    Posted Apr 17, 2020 01:18 AM
    In all versions on IMC it will be under system -> Depoly componets .
    if you are unable to see in IMC 7.3 E0705 , please let me know what the options you see under system tab ?
  • 3.  RE: How to view installed components through imc web portal
    Posted Apr 17, 2020 02:29 AM
    Thank you for your answer here is the exploded view of system menu:
  • 4.  RE: How to view installed components through imc web portal
    Posted Apr 20, 2020 04:12 AM
    This looks like some bug in firmware, can you please try to upgrade and check on the latest version E0705 P04  ?
  • 5.  RE: How to view installed components through imc web portal
    Posted Apr 20, 2020 11:21 AM
    I wasn't clear but this is for E0705 with latest available patch P04 installation on fresh virtual machine.
    [root@iMC ~]# uname -r
    3.10.0-1062.18.1.el7.x86_64
    [root@iMC ~]# uname -a
    Linux iMC 3.10.0-1062.18.1.el7.x86_64 #1 SMP Tue Mar 17 23:49:17 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
    [root@iMC ~]# mysql -V
    mysql Ver 14.14 Distrib 5.7.29, for Linux (x86_64) using EditLine wrapper
    More detailed info for IMC modules:
    UPDATE: I checked that last version that had Deploy Components in System menu was 7.3 (E0703). After update to E0705P04 this option is unavailable.
    Here it may be also worth to mention that as licensing for java has changed to run java web start application (jnlp file) under linux one can install:
    yum install IcedTea-Web
    there are also some other projects https://openwebstart.com/download/
    Unless HPE inlude or plans to include java license within IMC product. (I didn't find any information regarding this.)
