Wired Intelligent Edge
Howto: Configuring VRF and Inter VRF Routing in CX Switches
This thread has been viewed 26 times
  • 1.  Howto: Configuring VRF and Inter VRF Routing in CX Switches
    Posted Jun 26, 2023 09:56 AM
    Overview
    Virtual Routing and Forwarding (VRF) is a technology that allows multiple instances of a routing table to co-exist within the same router. Because the routing instances are independent, the same or overlapping IP addresses can be used without conflicting with each other.  The control and data plane are isolated in each VRF. This isolation keeps the traffic from crossing VRFs, and therefore multiple routing tables can coexist within the same physical L3 switch/router, without requiring multiple routers.
    Inter-Virtual Router Forwarding (IVRF) or route leaking allows for routes to leak (be distributed), across multiple VRFs in a controlled manner. Using an external system such as a firewall to provide routing is common, especially where additional security is required.
    Scenario
    A common use case where route leaking is useful is for shared services such as NTP, ClearPass (RADIUS), etc that exist in one VRF need to be accessible from a different VRF. That is the use case for this article, where I have NTP on 10.2.10.23, and ClearPass on 10.2.30.188, both in VRF default.
    A CX 8400 switch hosts these VRFs:
    • default
    • Sandpit - this VRF needs access to the resources in default
    Devices in different VRFs cannot access to each other until IVRF is enabled.
    Before I introduced new VRFs into this environment, everything was in the default VRF, and regular routing was used - this was certainly simpler. VRFs and IVRF enable additional functionality and capabilities, but they will not be necessary in all environments.
    References
    This is the high-level process flow for the 8400, from Chapter 11 Inter-Virtual Router Forwarding (IVRF).
    Configuration on a CX 8400
    All config was done with MultiEdit in Central, but you could use something else such as NetEdit or the CLI.
    VRFs and Route Distinguishers (RDs)
    vrf Sandpit
        rd 10.80.255.1:2
        address-family ipv4 unicast
            route-target export 10.80.255.1:2
            route-target import 10.80.255.1:1
        exit-address-family
    vrf default
        rd 10.80.255.1:1
            route-target export 10.80.255.1:1
            route-target import 10.80.255.1:2
        exit-address-family
    VLANs
    interface vlan 2001
        vrf attach Sandpit
        ip address 10.80.1.1/24
    interface vlan 2044
        vrf attach Sandpit
        ip address 10.80.44.1/24
    Router Config
    router ospf 2 vrf Sandpit
        router-id 10.80.255.1
        trap-enable
        area 0.0.0.0
    router ospf 1
        trap-enable
        redistribute bgp
        redistribute connected
        redistribute static
        area 0.0.0.0
    router bgp 65080
        bgp router-id 10.80.255.1
        bgp log-neighbor-changes
            redistribute ospf
        exit-address-family
        vrf Sandpit
            no bgp fast-external-fallover
                redistribute ospf
                network 10.80.0.0/16
                aggregate-address 10.80.0.0/16 summary-only
            exit-address-family
    Additional Services
    DNS is specific to each VRF - you will get name resolution errors unless you also include DNS for each VRF.
    ip dns server-address 10.20.30.85 vrf Sandpit
    ip dns server-address 10.50.0.100 vrf Sandpit
    If DHCP-server is running on the switch, this can also be allocated to the relevant VRF.
    dhcp-server vrf Sandpit
        pool vlan2001
            range 10.80.1.101 10.80.1.249 prefix-len 24
            default-router 10.80.1.1
            dns-server 10.20.30.85 10.50.0.100
            lease 30:01:02
            exit
        authoritative
        enable
    Testing
    This is what the routing looked like in the default VRF before enabling dynamic IVRF:
    This is what the routing looked like after enabling dynamic IVRF - default VRF:
    This is what the routing looked like after enabling dynamic IVRF - view from Sandpit VRF:
    Richard Litchfield
    Airheads MVP 2020, 2021, 2022
