Comware
  • 1.  howto connect 100MB Switches ?
    Posted Aug 14, 2004 12:46 PM
    hi
    do I need special 100 Ohm cables to connect
    four DELL Power Connect 3024 (100MB) switches,
    or the normal RJ45 patch cables are OK ?
    kind regards
    chris
  • 2.  RE: howto connect 100MB Switches ?
    Posted Aug 15, 2004 06:16 PM
    Have you considered posting your question here - http://forums.us.dell.com/supportforums/board?board.id=pc_managed
    No, regular "RJ45" patch cables won't work, and by the way, the RJ45 refers to the connector, not the cable. There are different types of patch cables with RJ45 connectors, so you need to learn more about basic networking before plunging in at the deep end.
    You can daisy chain the switches using cross-over cables, however you'd be better off using the LVDS stacking cables to create a single stack.
  • 3.  RE: howto connect 100MB Switches ?
    Posted Aug 16, 2004 06:52 AM
    Hi Chris,
    if you refer to a simple network with short lenght cables the answer is NO. UTP-8 cables can be used for 10 and 100 Mbs.
    If you have a big building then answer is YES, it's better use STP-8 cables.
    The difference is UTP are unshielded cables while STP (shielded twisted pair) are shielded cables.
    If you have a big building it better certificate all cables so you are sure tehy works fine and can carry 100mbs signal.
    Antonio Vigliotti
