If I were you I'll go with an original (genuine) HPE Transceiver (1G SFP BiDi Transceivers JD098B or JD099B?) for you HPE OfficeConnect 1910-48G Switch (ex 3Com Baseline Plus Switch 2952)...just to avoid any potential incompatibility issue you're not aware of (some third-party transceivers may be recognized, some others may not be recognized) and to stay safe.
OTOH if you already own/have that transceiver...you may try a test to see if the HPE 1910 will be able to correctly recognize it.
