Comware
HP 1920-24G schedule reboot datetime format
  • 1.  HP 1920-24G schedule reboot datetime format
    Posted Jun 23, 2016 04:06 AM
    Hi everyone,
    I have a trouble with a scheduled task on HPE switches (HP 1920-24G JG924A).
    I use SSH to schedule a reboot. When I set :
    "schedule reboot at 10:15" : it works (reboot ok)
    "schedule reboot at 23:00" : it doesn't work (no reboot)
    is there a limitation about the datetime format ?
  • 2.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 23, 2016 06:07 AM
    Is the system time properly/correctly set on the Switch?
    <HP1920-8G_A>schedule reboot at ?
      STRING  Exact time(hh:mm)
    <HP1920-8G_A>display time-range all
    Current time is 12:03:28 6/23/2016 Thursday
    Which Firmware version are you running on your HPE OfficeConnect 1920-24G (mine is at R1112)?
    <HP1920-8G_A>display ntp-service status
    Clock status: synchronized
    Clock stratum: 3
    Reference clock ID: 193.234.225.237
    Nominal frequency: 100.0000 Hz
    Actual frequency: 100.0000 Hz
    Clock precision: 2^18
    Clock offset: -3.7511 ms
    Root delay: 32.03 ms
    Root dispersion: 4.65 ms
    Peer dispersion: 2.67 ms
    Reference time: 10:06:49.979 UTC Jun 23 2016(DB163339.FACC2D6A)
    <HP1920-8G_A>display ntp-service sessions
    source reference stra reach poll now offset delay disper
    [12345]193.234.225.237 193.204.114.233 2 63 64 39 -4.4 28.5 1.2
    [245]94.23.66.89 193.204.114.233 2 63 64 30 -13.2 44.9 2.0
    note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
    Total associations : 2
    <HP1920-8G_A>display ntp-service trace
    server 127.0.0.1,stratum 3, offset -0.006649, synch distance 0.02237
    server 193.234.225.237,stratum 2, offset 0.007407, synch distance 0.00273
    server 193.204.114.233,stratum 1, offset -0.014117, synch distance 0.00015
    refid CTD
    <HP1920-8G_A>schedule reboot at 23:30 Reboot system at 23:30 06/23/2016(in 11 hour(s) and 23 minute(s)). confirm? [Y/N]:Y <HP1920-8G_A>display schedule reboot System will reboot at 23:30 06/23/2016 (in 11 hours and 23 minutes).
    Are the settings above similar to your ones (NTP apart)?
    The schedule reboot at 23:30 command generated this log line:
    %Jun 23 12:06:10:969 2016 HP1920-8G_A CMD/5/CMD_REBOOT_SCHEDULED: vty0(192.168.0.10) set schedule reboot parameters at 12:06:10 06/23/2016, and system will reboot at 23:30 06/23/2016.
  • 3.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 24, 2016 05:43 AM
    Indeed it rebooted at scheduled time (23:30):
    System will reboot at 23:30 06/23/2016 (in 0 hours and 6 minutes).
    System will reboot at 23:30 06/23/2016 (in 0 hours and 3 minutes).
    <HP1920-8G_A>
    %Jun 23 23:29:28:030 2016 HP1920-8G_A CMD/4/CMD_REBOOT_SOONAFTER:
    *** --- REBOOT IN ONE MINUTE ---
    #Jun 23 23:30:28:048 2016 HP1920-8G_A DEVM/1/REBOOT:
     Reboot device by command.
    %Jun 23 23:30:28:139 2016 HP1920-8G_A DEVM/5/SYSTEM_REBOOT: System is rebooting now.
    System is starting...
    But now I've a doubt: when I first issued the schedule reboot at 23:30 command during yesterday afternoon I saved the system configuration (safely) via CLI and finally closed the Telnet session leaving the Switch turned on.
    Once I logged again yesterday late night (just few minutes before the scheduled reboot time and after few hours since the command was executed) I suddenly issued a display schedule reboot command to check the status of the scheduled reboot and noticed the Switch reported nothing (no scheduled reboot at all): I re-issued the very exactly schedule reboot at 23:30 command (the Switch accepted the command as it was the very first time it was committed) and verified that the schedule reboot was correctly displayed/reported *again* (as happened in the afternoon), then I waited to see what happens.
    The Switch rebooted (see above).
    I also checked that the Switch didn't reboot *before* the scheduled reboot time.
    The question is:
    Does interrupting Telnet session impact (erase) the committed command (schedule reboot) or was it only a glitch on the Switch?
    In other words:
    Do we need to keep the session constantly open to permit the command to be executed (at scheduled time) or that isn't relevant at all?
  • 4.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 27, 2016 03:46 AM
    Hi parnassus,
    Thanks for your answer,
    -> Yes it is.
    <HP 1920G Switch>schedule reboot at ?
    <HP 1920G Switch>display time-range all
    Current time is 08:26:40 6/27/2016 Monday
    It depends on the switch. I've about 70 switches in R1111 and R1112 the problem is for both.
    In fact my goal is to upgrade the switch from R1111 to R1112 that's why I want to schedule a reboot.
    <HP 1920G Switch>display ntp-service status
     Clock stratum: 2
     Reference clock ID: X.X.X.X
     Clock offset: 3.5307 ms
     Root delay: 10.86 ms
     Root dispersion: 10.39 ms
     Peer dispersion: 10487.70 ms
     Reference time: 07:29:48.433 UTC Jun 27 2016(DB1B546C.6EFDEB52)
    <HP 1920G Switch>display ntp-service sessions
    [12345]X.X.X.X        LOCL               1   255   64   39    0.0   10.9   17.0
    Total associations :  1
    <HP 1920G Switch>display ntp-service trace
     server 127.0.0.1,stratum 2, offset -0.009980, synch distance 10.53795
     server X.X.X.X,stratum 1, offset -0.052444, synch distance 10.48975
     refid LOCL
    <HP 1920G Switch>schedule reboot at 23:30
    Reboot system at 23:30 06/27/2016(in 14 hour(s) and 56 minute(s)). confirm? [Y/N]:Y
    <HP 1920G Switch>display schedule reboot
    System will reboot at 23:30 06/27/2016 (in 14 hours and 56 minutes).
    This is the generated command :
    %@10419%Jun 27 08:33:30:625 2016 HP 1920G Switch CMD/5/CMD_REBOOT_SCHEDULED: vty0(X.X.X.X) set schedule reboot parameters at 08:33:30 06/27/2016, and system will reboot at 23:30 06/27/2016.
    The question is:
    In other words:
    I use SSH and not Telnet. For SSH, i tested a schedule reboot in 10min. I closed the SSH connexion and the switch correctly rebooted. But the same thing for 23:00 (in 10 hours for example) didn't work. I haven't tried to leave the SSH connexion open. I'll try it tonight.
  • 5.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 27, 2016 03:59 AM
    I have a preference for the glitch. Because if I close the SSH connexion and reboot is scheduled in 10-20min it's ok. But if the reboot is scheduled in 8-9-10 hours it doesn't work.
  • 6.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 27, 2016 07:36 AM
    Could it be that the NTP synchronization, once happened (in a time range of few hours it probably happens more frequently than in a time range of only 10/20 minutes), is able to disrupt the (scheduled reboot) countdown?
    Will be interesting to make a test with NTP Synchronization disabled at all. In both cases it looks like a Bug.
  • 7.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 27, 2016 08:01 AM
    It's a good question...
    I've disabled the NTP and scheduled a reboot at 23:00. I tell you tomorrow what happens.
  • 8.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 28, 2016 01:50 AM
    It works !
    The trouble is due to NTP ...
    Where can I contact HP Team to feedback (bug report) about it ?
  • 9.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 28, 2016 10:37 AM
    My Network -> My Support -> Select a (registered?) Product -> Web Case Support (support by E-mail) -> Case Submission.
  • 10.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 28, 2016 05:17 PM
    I'm curious how support will handle this.  You're using CLI, which officially isn't supported.
  • 11.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 29, 2016 03:01 AM
    Thank you.
    Yes, officially isn't supported but I don't require a correction. It is just for knowledge then they will do as they like :)
    It will be interesting to see.
  • 12.  RE: HP 1920-24G schedule reboot datetime format
    Posted Jun 29, 2016 03:51 AM
    The day (maybe never if nobody issue a Feature Request) the HPE OfficeConnect 1920 Switch Series will let to schedule a reboot through its Web GUI with NTP enabled...well...that day this issue will become officially relevant!
    Until that day, as it was pointed out, it's just additional specific knowledge we gained by trials and errors.
  • 13.  RE: HP 1920-24G schedule reboot datetime format
    Posted Oct 19, 2017 04:08 AM
    Thanks for your analysis. You guys are awesome and just saved me a lot of hassle.
    I guess for reboots/upgrades outside of business hours I'll have to revert to using an
    old-fashioned alarm clock and logging into my office from home.
    <sarcasm>How could anyone possibly make better use of his free time?</sarcasm>
  • 14.  RE: HP 1920-24G schedule reboot datetime format
    Posted Oct 19, 2017 04:49 AM
    Yeah!
    My take: we all will start to have real free time the day devices will auto-manage themself in total autonomous way (so any actual implemented auto-xxx feature will be interesting if useful and robust enough to not cause unnecessary unwanted disruptions on running devices if compared to the same without that auto-xxx feature enabled)...at present time we have just two options regarding correctly working devices: (a) forget them until they break and (b) manage them to avoid they break.
