Become a Member
Hello all, I am new in HP technology. By mistake I have delete everything of my HP 1920 switch. Now, how can I push new firmware to my switch to run. thank you for your advice.
Hello Rashed,
If your device is 1920 (not 1920s) you can use the following link to download the firmware please check which is your model before downloading and usnig the firmware:
HPE 1920 48G Switch (JG927A):
https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JG927A
HPE 1920 48G PoE+ (370W) Switch (JG928A):
https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JG928A
Then you can use the procedure in the release notes from the following link on page 30 (Upgrading from the BootWare menu):
https://support.hpe.com/hpesc/public/docDisplay?docId=a00069833en_us
Hope this helps!
Thank you so much Alex. I will follow your instruction. If I found some difficulties then will msg here.
Hello Alex. Thank you so much. I have got access on the switch. Now I am facing another issue. May be it simple but I said I am new in HP tech. After updating I can't get switch menu that I can configure. I mean it doesn't show on cli (switch>) like this. it shows <HPE> and it doesn't recognise regular command. Thank you for your time and advice.
Please check the user guide for this switch:
HPE OfficeConnect 1920 Switch Series User Guide
Hi
I know its 3years later, but i have same problem. But if i trying to open that link it opens dashboard. How can i get firmware?
