Comware
HP 1950-24G (JG960A) Switch - Setting Trunks
  • 1.  HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 04, 2016 10:21 AM
    I have HP 1950-24G (JG960A) Switch and trying to setup a trunk (Trk3) to match the setup on my core switch.
    There is very little on this setup/info.
    How do I go about doing this?
    I like all trunk traffic from core switch to go through an SFT (gibic connection) and onto the 1950 switch on another SFP/gibic connection.  have several VLANs on core I want to trunk throught o my edge switch (1950)
    Your advise much appreciate...
  • 2.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 04, 2016 02:22 PM
    Port Trunking (with the use of LACP or Static) is nothing fancy and nothing was hidden or misterious (there are plenty of posts and very good documentation about it and also about what you want to achieve...which is basically "creating one or more Port Trunks using Copper/SFP+ ports and permitting some/all VLAN to traverse it")...just start reading the HPE OfficeConnect 1950 Switch Series User Guide.
    Read the "Network services features" chapter, "Link aggregation" paragraph starting from page 27 and if you need some configuration examples look for "Port Trunking" or "LACP Trunks" here.
    As example (maybe not the best and for sure not the only one you will find but, at least, one where I personally did some port trunking practice between HPE OfficeConnect 1920 Switches, very similar to the 1950) can be found here.
  • 3.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 05, 2016 09:28 AM
    Thanks parnassus for the advise.
    Did you leave a link where you mention port truniking as I cant get to it.
    Ive tried a variety of configurations and even exporting cfg and editing in notepad to include the extra trunk commands, but still cant get the SFT/gibics conenctor communiting back to our core switch.
    Is anyone able to advise where I am going wrong from the config i pasted below.
    thanks
    version 7.1.045, Release 313P03
    sysname HP-1950-24G
    telnet server enable
    irf mac-address persistent timer
    irf auto-update enable
    undo irf link-delay
    irf member 1 priority 1
    transceiver phony-alarm-disable
    password-recovery enable
    vlan 1
    vlan 13
    description Servers
    vlan 14
    description PC
    vlan 15
    description Printers
    interface Bridge-Aggregation1
    interface Vlan-interface13
    ip address 192.168.13.5 255.255.255.0
    ip gateway 192.168.13.10
    interface GigabitEthernet1/0/1
    port link-type hybrid
    undo port hybrid vlan 1
    port hybrid vlan 13 untagged
    port hybrid pvid vlan 13
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10
    interface GigabitEthernet1/0/11
    interface GigabitEthernet1/0/12
    interface GigabitEthernet1/0/13
    interface GigabitEthernet1/0/14
    interface GigabitEthernet1/0/15
    interface GigabitEthernet1/0/16
    interface GigabitEthernet1/0/17
    interface GigabitEthernet1/0/18
    interface GigabitEthernet1/0/19
    interface GigabitEthernet1/0/20
    interface GigabitEthernet1/0/21
    interface GigabitEthernet1/0/22
    interface GigabitEthernet1/0/23
    interface GigabitEthernet1/0/24
    interface Ten-GigabitEthernet1/0/25
    port link-type trunk
    port trunk permit vlan 1
    port link-aggregation group 1
    interface Ten-GigabitEthernet1/0/26
    interface Ten-GigabitEthernet1/0/27
    interface Ten-GigabitEthernet1/0/28
    scheduler logfile size 16
    line class aux
    authentication-mode scheme
    user-role network-admin
    line class vty
    user-role network-operator
    line aux 0
    line vty 0 63
    snmp-agent
    snmp-agent local-engineid 800063A2802C233AD411FA00000001
    snmp-agent community write private
    snmp-agent community read public
    snmp-agent sys-info version all
    domain system
    domain default enable system
    role name level-0
    description Predefined level-0 role
    role name level-1
    description Predefined level-1 role
    role name level-2
    description Predefined level-2 role
    role name level-3
    description Predefined level-3 role
    role name level-4
    description Predefined level-4 role
    role name level-5
    description Predefined level-5 role
    role name level-6
    description Predefined level-6 role
    role name level-7
    description Predefined level-7 role
    role name level-8
    description Predefined level-8 role
    role name level-9
    description Predefined level-9 role
    role name level-10
    description Predefined level-10 role
    role name level-11
    description Predefined level-11 role
    role name level-12
    description Predefined level-12 role
    role name level-13
    description Predefined level-13 role
    role name level-14
    description Predefined level-14 role
    user-group system
    local-user admin class manage
    service-type telnet terminal http https
    authorization-attribute user-role network-admin
    authorization-attribute user-role network-operator
    ip http enable
    ip https enable
    return
  • 4.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 05, 2016 10:54 AM
    Mmm...your interface Bridge-Aggregation 1 section lacks of some settings (keep in mind that permitted VLANs IDs should be declared on the line port trunk permit vlan). Below I used dynamic (so LACP)...it depends on what is configured on your Core...
     port trunk permit vlan 1 <add here VLANs IDs you want to permit>
     link-aggregation mode dynamic
    Then on physical interfaces (Ten Gigabit Ethernet port 1/0/25 and 1/0/26, via SFP+ 10G Transceivers) you want to be binded to the logical interface Bridge-Aggregation1 (group 1) you need:
     port trunk permit vlan 1 <add here the same VLANs IDs declared above>
    But it's really important that you understand and follow the right sequence of commands (especially on Comware based Switches) to deploy the correct configuration: try to read any Comware 7 based Switch manual about Layer 2 (as example, pick up the manual HPE FlexFabric 5700 Switch Series - Layer 2 LAN Switching Configuration Guide), there you will find an entire chapter "Configuring Ethernet link aggregation" with examples on how to correctly configure Link Aggregation on Comware 7,  just follow the sequence.
  • 5.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 06, 2016 04:55 AM
    Once again parnassus, thanks for helping with the command structure for 1950 switch.
    What I am noticing is the switch does not accept the commands and even if i hard code these itno a startup.cfg file and import into the switch the "interface Bridge-Aggregation1" setup is lost/stripped out.
    I lose  the below commmands
  • 6.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 06, 2016 05:01 AM
    Switch summary:
    S/N: CN5BGQ*****
    Device type: JG960A
    HPE Comware Platform Software
    HPE Comware Software, Version 7.1.045, Release 3113P03
    Copyright (c) 2010-2016 Hewlett Packard Enterprise Development LP
    HPE OfficeConnect 1950-24G-2SFP+-2XGT uptime is 0 weeks, 0 days, 0 hours, 18 minutes
    Slot 1:
    Uptime is 0 weeks,0 days,0 hours,18 minutes
    HPE OfficeConnect 1950-24G-2SFP+-2XGT JG960A with 1 Processor
    BOARD TYPE: 1950-24G-2SFP+-2XGT
    DRAM: 1024M bytes
    FLASH: 512M bytes
    PCB 1 Version: VER.D
    Bootrom Version: 143
    CPLD 1 Version: 001
    Release Version: HPE OfficeConnect 1950-24G-2SFP+-2XGT JG960A-3113P03
    Patch Version : None
    Reboot Cause : UserReboot
    [SubSlot 0] 24GE+2SFP-Plus+2XGT
    <HP-1950-24G>
  • 7.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 06, 2016 05:32 AM
    What do you mean with "the switch does not accept the commands"?
    You shouldn't necessarily operate directly on the configuration file with a text editor!
    You should instead start with a "clean" (not borked) Switch configuration (if you can, if it is still clean) and then, via CLI or via Web GUI perform the necessary configuration steps.
    I think that Web GUI could be easy enough...but if you like CLI go with the CLI providing that you know how to interact with it (see Appendix A "Managing the device from the CLI" of the PDF manual I linked above).
    Note that some commands depend on the user role: if you are in "user view" some commands aren't available...to quote the manual "However, the commands you can use depend on the user roles you have. By default, a command is available for the predefined user roles. You can use the RBAC feature to assign a command to additional user roles from the Web interface." so you first need to verify which role was used to issue those (unaccepted) commands...and then act to use the right user role for the tasks you want to achieve (see page 20 of that manual for RBAC concepts and settings configurable via Web GUI).
  • 8.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 06, 2016 10:07 AM
    doing "system-view" after entering #xtd-cli-mode# done the trick on the HP-1950 (JG960A)
  • 9.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Oct 06, 2016 01:38 PM
    Glad you found the magic command that unlocked the door!
    P.S. it's valid on every Comware based Switch (Comware 5 and 7).
  • 10.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Dec 15, 2016 04:58 AM
    How did U enter the xtd-cli-mode ? What was the password ?
    Mikies
  • 11.  RE: HP 1950-24G (JG960A) Switch - Setting Trunks
    Posted Dec 20, 2016 09:07 AM
    I have 1920's, but I assume its the same if its Comware....
    Login via the CLI and proceed as below.
    * Copyright (c) 2010-2015 Hewlett-Packard Development Company, L.P. *
    * Without the owner's prior written consent, *
    * no decompiling or reverse-engineering shall be allowed. *
    Login authentication
    Username:admin
    Password:
    <SWITCH-01>_cmdline-mode on
    All commands can be displayed and executed. Continue? [Y/N]y
    Please input password:**********************         (password is Jinhua1920unauthorized)
    Warning: Now you enter an all-command mode for developer's testing, some commands may affect operation by wrong use, please carefully use it with our engineer's direction.
    <SWITCH-01>sys
    System View: return to User View with Ctrl+Z.
    [SWITCH-01]
    you should now have access to all configuration commands
