Comware
  • 1.  HP 1950 JG961A "xtd-cli-mode"
    Posted Dec 15, 2016 03:56 AM
    HP 1950 JG961A- HPE Comware Software, Version 7.1.045, Release 3115P03
     User : admin
    User Role : network-admin  & network-operator
    Could somebody told me whats the password to the "xtd-cli-mode" ?
    After the help command  ' ? " switch show options :
    display Display current system information
    initialize Delete the startup configuration file and reboot system
    ipsetup Configure an IP address for VLAN-interface 1
    password Specify password of local user
    ping Ping function
    poe Power over Ethernet
    quit Exit from current command view
    reboot Reboot operation
    summary Display summary information of the device
    telnet Establish a telnet connection
    transceiver Enable transceiver phony alarm
    undo Cancel current setting
    upgrade Upgrade the system boot file or the Boot ROM program
    xtd-cli-mode Switch to extended CLI mode to display and execute all commands
    (special authorization required)
    Mikies
  • 2.  RE: HP 1950 JG961A "xtd-cli-mode"
    Posted Dec 15, 2016 07:58 AM
    Are you aware about this "Warning: Extended CLI mode is intended for developers to test the system. Before using commands in extended CLI mode, contact the Technical Support and make sure you know the potential impact on the device and the network"?
  • 3.  RE: HP 1950 JG961A "xtd-cli-mode"
    Posted Dec 03, 2020 09:42 AM
    You mean the "advanced developer" commands like configuring ports on the switch?  This switch is retarded.
  • 4.  RE: HP 1950 JG961A "xtd-cli-mode"
    Posted Jun 22, 2017 09:28 AM
    Hello.
    I'm here, thinking...
    What is the purpose of this password?
    That's absolutely ridiculous.
    The password needed take away my freedom to configure advanced resources in the equipment that I bought to this purpose.
    Please bring back the system-view to the switch without this password, like HP5120, HP5130, HP3600 switches...
    Well, my friend, the password is:
    foes-bent-pile-atom-ship
  • 5.  RE: HP 1950 JG961A "xtd-cli-mode"
    Posted Oct 02, 2018 02:33 PM
    This is for IMC access so the switch can be managed by the central management system.
  • 6.  RE: HP 1950 JG961A "xtd-cli-mode"
    Posted Apr 18, 2019 09:23 AM
    How can I change this default password?
