And when I tried to access that PC remote it was not able to then physically accessed the PC and network was gone
Original Message:
Sent: Nov 27, 2024 02:13 AM
Subject: HP-2530
Thanks !
Now coming to the exact ports and VLANs
My requirement as below, please advise so that I can proceed
I want to try the same on only 1 PC which has details as --- Since it is Production Environment so if success I will repeat for all other ports
172.16.2.53/24 on Port 15
So I have to change as under - I will only add which is in bold, Please advise!
vlan 2
name "USERS"
untagged 2-29,31-43,46-48
tagged 1,15,16
no ip address
exit
Rest unchanged - IS it OK ?
vlan 15
name "VM"
untagged 30
tagged 1,15
no ip address
exit
vlan 16
name "VM-1"
tagged 1,15
no ip address
exit
Original Message:
Sent: Nov 26, 2024 10:06 PM
Subject: HP-2530
Sorry I put only the example for one switch.
Could you try these commands on 2530 and test it. I put interfaces range gig 10-29 like an example, please put your interfaces as tagged:
vlan 2 name "USERS" untagged 2-9,31-43,46-48 tagged 1,10-29 no ip address exitvlan 7 name "PRINTERS" untagged 44-45 tagged 1 no ip address exitvlan 15 name "VM" untagged 30 tagged 1,10-29 no ip address exitvlan 16 name "VM-1" tagged 1,10-29 no ip address exit
