Comware
  • 1.  Hp 2626 and loop-detection
    Posted Mar 05, 2008 09:44 AM
    Hey
    I have a HP 2626 switch, that runs with firmware H.10.50 and i want to setup loop-detection, but i understand that i have to setup spanning tree aswell, is this true? i would prefure not to run spanning tree in my network, do to company police. can anyone confirm this? or maybe give me a solution to this problem.
    Thanks..
  • 2.  RE: Hp 2626 and loop-detection
    Posted Mar 05, 2008 11:57 AM
    How about enabling bpdu-filter on all the ports?
  • 3.  RE: Hp 2626 and loop-detection
    Posted Mar 05, 2008 09:42 PM
    loop-protect is independent of spanning tree,
    I'd recommend:
    loop-protect 1-24
    loop-protect disable-timer 300
  • 4.  RE: Hp 2626 and loop-detection
    Posted Mar 06, 2008 05:09 AM
    I have set the loop-protect 1-24 and
    loop-protect disable-timer but i have set the disable-timer to 0 so that it just clos down the port when it detects a loop, but i dont shutdown the port. I have also set the test count for loop to 5 sec.. Is this because i dont run with spanning tree that it dont work?
  • 5.  RE: Hp 2626 and loop-detection
    Posted May 28, 2008 03:45 AM
    I also did some testing with loop protect.
    It seems that you have to set a disable timer(for exmpale 30seconds).
    And you have to set de transmit interval to 1 second.
    In that case it seems to work most of the time.
