Wired Intelligent Edge
  • 1.  HP 2920 Switch ssl: ST1-CMDR: User :TLS connection failed for WEB-UI session from x.x.x.x. (1 ti
    Posted Nov 05, 2020 08:25 PM
    HP 2920 Switch ssl: ST1-CMDR: User :TLS connection failed for WEB-UI session from x.x.x.x. (1 times in 60 seconds)
    How do I stop fix this?
    it's driving me crazy.
  • 2.  RE: HP 2920 Switch ssl: ST1-CMDR: User :TLS connection failed for WEB-UI session from x.x.x.x. (1 ti
    Posted Nov 06, 2020 02:14 AM
    HI,
    There are certain things you need to confirm:
    1. Are you getting this error for particular role, like error while login as manager or admin and no error while login as operator?
    2. Is the local authentication or radius server authentication?
    3. Have you tried on different browser?
    4. What is device product number 'JXXXXX' and software version?
    Thanks!
  • 3.  RE: HP 2920 Switch ssl: ST1-CMDR: User :TLS connection failed for WEB-UI session from x.x.x.x. (1 ti
    Posted Feb 01, 2021 07:03 PM
    I'm having the same issue
    Logged in via putty using Admin.  Local authentication only.
    switch model j9727a
    Regards
  • 4.  RE: HP 2920 Switch ssl: ST1-CMDR: User :TLS connection failed for WEB-UI session from x.x.x.x. (1 ti
    Posted Feb 11, 2021 11:02 AM
    We 'are seeing this referencing our IMC host. Any update?
  • 5.  RE: HP 2920 Switch ssl: ST1-CMDR: User :TLS connection failed for WEB-UI session from x.x.x.x. (1 ti
    Posted May 08, 2021 11:34 AM
    I see these in Syslog, coming from PRTG Network Monitor address.
