dear all >>
I have a problem on my E-Series switches are connected via a trunk on an A-series switch.
I get in the log is always the info:
00828 lldp: PVID mismatch on port B22(VID unknown)with peer device port Ten-GigabitEthernet1/0/10(VID 1)(4831)
vlans are same at both sides .
5400zl switches are the core in our site connected to a5500 series .
i use the this command to stop the notification no lldp config dot1TlvEnable port-vlan-id but its still up >>
what should i do .
