When the Juniper reboots, the copper port does not always "connect". The spanning-tree state for the interface is disabled. If I configure a new port with all the same setting and move the connection there, it connects.
Port Settings (show run interface A8):
interface A8
name "Internet"
untagged vlan 229
lldp admin-status disable
spanning-tree admin-edge-port
spanning-tree bpdu-filter pvst-filter
exit
The lldp admin-status disable prevents neighbour messages from being sent or received. The spanning-tree admin-edge-port should cause the port to start forwarding immediately with no STP "listening". The filters should prevent the receiving of spanning-tree info from the Juniper.
We have 2 ports connected to their Juniper. We had to power events that caused only the providers Juniper to reboot (our UPS is larger. They will replace their UPS soon). The first time the event log shows:
(In Time order)
5/31/2018, 5:15:38 PM port A1 is now off-line
5/31/2018, 5:15:39 PM port A8 is now off-line
5/31/2018, 5:19:08 PM port A1 is Blocked by STP
5/31/2018, 5:19:08 PM port A1 is now on-line
5/31/2018, 5:19:10 PM port A8 is Blocked by STP
5/31/2018, 5:19:10 PM port A8 is now on-line
I tested at 5:30pm and all is good. The next power events:
6/1/2018, 5:29:17 AM port A1 is now off-line
6/1/2018, 5:29:18 AM port A8 is now off-line
6/1/2018, 5:32:41 AM port A1 is Blocked by STP
6/1/2018, 5:32:41 AM port A1 is now on-line
No message about A8. I tried a disable/enable and unplugging the transciever, nothing. Configured A3 to match A8 and moved the transceiver there, all is good.
Another piece of information, the copper transciever is a generic copper transceiver.
I am updating the firmware on the 5406 and recabling to make sure there is a HPE/Aruba Transceiver in that port.
Anyone have any other ideas?
