Hi all,
I've got 2 HP 5500 HI switches that I'm trying to connect with IRF, with one pair of 10Gbe SFP+ transceivers connected with a fibre cable. I've followed all the guides I can find and have set it up as I think it should be but when I connect the 2 switches, they initially show IRF port as up before failing with a heartbeat timeout message. I've made sure the switches are on the same firmware. Here's my config for the master switch:
version 5.20.99, Release 5501P20
sysname HP
dhcp relay server-group 1 ip 10.1.0.149
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 32
domain default enable system
telnet server enable
password-recovery enable
acl number 2000
rule 0 deny source 172.16.28.0 0.0.3.255
acl number 3001
hardware-count enable
rule 0 deny ip source 172.16.28.0 0.0.3.255 destination 192.168.10.0 0.0.0.255
rule 5 deny icmp source 172.16.28.0 0.0.3.255 destination 192.168.10.0 0.0.0.255
rule 10 permit ip
vlan 1
vlan 10
description Accounts
vlan 20
description Servers
vlan 30
description Curriculum
vlan 40
description Printers
vlan 60
description IT Admin
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$1Q8Fu74tA+WUcpcTGeKWn2/UizAb4H3k7Q==
authorization-attribute level 3
service-type telnet
service-type web
cwmp
undo cwmp enable
interface NULL0
interface Vlan-interface1
ip address 10.1.3.67 255.255.0.0
interface Vlan-interface10
ip address 192.168.10.1 255.255.255.0
dhcp select relay
dhcp relay server-select 1
packet-filter 3001 inbound
interface Vlan-interface20
ip address 192.168.20.1 255.255.255.0
dhcp select relay
interface Vlan-interface30
ip address 172.16.28.1 255.255.252.0
dhcp select relay
interface Vlan-interface40
ip address 192.168.40.1 255.255.255.0
dhcp select relay
interface Vlan-interface60
ip address 192.168.60.1 255.255.255.0
dhcp select relay
interface GigabitEthernet1/0/1
port link-mode bridge
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface M-GigabitEthernet0/0/0
interface Ten-GigabitEthernet1/0/30
interface Ten-GigabitEthernet1/0/29
ip route-static 0.0.0.0 0.0.0.0 10.1.10.2
dhcp enable
ssh server enable
load xml-configuration
load tr069-configuration
user-interface aux 0
user-interface vty 0 15
irf-port 1/1
port group interface Ten-GigabitEthernet1/0/29 mode enhanced
return
Here's the config on the slave switch:
sysname HP
undo irf link-delay
vlan 1
domain system
state active
idle-cut disable
user-group system
local-user admin
password cipher $c$3$mAOPzI066QeH3djBbCybHk3DyaQ8SSo5TA==
service-type telnet
service-type web
cwmp
undo cwmp enable
interface NULL0
ip address 10.1.3.75 255.255.0.0
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Ten-GigabitEthernet2/0/29
interface Ten-GigabitEthernet2/0/30
user-interface aux 1
irf-port 2/1
port group interface Ten-GigabitEthernet2/0/30 mode enhanced
return
I can't work out what it is that I'm doing wrong. Can anyone help?
Thanks in advance
#irf
