Comware
  • 1.  HP-5510
    Posted Dec 06, 2024 05:10 AM
    I have HP-5510 where in I tried to configure HP to use NTP but no help.
    I enabled NTP service but not able to understand as to what to configure in Auth Key ID etc...
    Attached is the screenshot of GUI of HP-5510
    Kindly advise how to configure the same so that HP-5510 uses NTP and automatically updates its Date / Time
    Manish
  • 2.  RE: HP-5510
    Posted Dec 07, 2024 02:54 AM
    Just enter IP address of the NTP server and that's it.
    Auth Keys are used when you connect to secure NTP server. If you don't have that, then it's not needed.
    In CLI:
    clock protocol ntp
    ntp-service enable
    ntp-service unicast-server <ntp server ip or dns>
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 3.  RE: HP-5510
    Posted Dec 08, 2024 05:20 AM
    Thanks for the help
    I am in India and switch displays date in MM/DD/YYYY and want to display it in DD/MM/YYYY
    Can you help me with command ?
    Manish
  • 4.  RE: HP-5510
    Posted Dec 08, 2024 05:46 AM
    Hi Manish.
    I would also like to have this feature but I'm not aware of it.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 5.  RE: HP-5510
    Posted Dec 08, 2024 06:38 AM
    Hi
    Thanks a lot!
    Manish
