Comware
  • 1.  HP-5510 / HP-2530 / HP-1950 Firmware Update
    Posted Nov 26, 2024 05:22 AM
    I want to download latest firmware for HP-5510 / HP-2530 / HP-1950. From where can I download. Is there any way to know if these switches have latest firmware to be downloaded
    Please help!
    Manish
  • 2.  RE: HP-5510 / HP-2530 / HP-1950 Firmware Update
    Posted Nov 26, 2024 06:13 AM
    Hello Manish,
    You can find the last firmware version for these switches here:
    https://networkingsupport.hpe.com/downloads
    You can filter by model devices and you can see the last firmware.
    Daniel Ruiz
    If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
    Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 3.  RE: HP-5510 / HP-2530 / HP-1950 Firmware Update
    Posted Nov 26, 2024 06:58 AM
    I need to confirm before download and upgrade.
    I have
    HPE 5510 24G 4SFP+ HI 1-slot Switch JH145A so will 5510HI_7.10.R3507P18.zip work ?
    HPE Comware Platform Software, Software Version 7.1.070, Release 3507P09 HPE 1950 24G 2SFP+ 2XGT PoE+ Switch so will 1950_7.10.R3507P08.zip work?
    Aruba-2530 YA.16.11.0011 so will YA_16_11_0021.swi work ?
    Please advise !
  • 4.  RE: HP-5510 / HP-2530 / HP-1950 Firmware Update
    Posted Nov 26, 2024 09:56 PM
    Yes, these are the latest firmware releases for those devices, and they should work. However, my advice is to read the release notes for each firmware, to make sure there are no issues.
    Best Regards
    Daniel Ruiz
