Comware
HP 8206zl Module crashed
  • 1.  HP 8206zl Module crashed
    Posted Oct 14, 2010 02:58 AM
    My 8206zl sw is crashed two times. Because of a device with generating "port A23-Excessive jabbering/fragments. See Help" log. After some time then the module download its code from. Here is the log;
    W 10/14/10 04:00:40 00274 chassis: (82) Ports A: Blade Crash detected - Available
    I 10/14/10 04:00:45 00375 chassis: Slot A Downloading
    I 10/14/10 04:00:47 00376 chassis: Slot A Download Complete
    W 10/14/10 04:00:55 00274 chassis: Slot A Software exception in ISR at interrupt s_bts.c:3005 -> IBP FRC 40 400000 7ff 80fe0000
    I 10/14/10 04:01:05 00422 chassis: Slot A Ready
    Then the other crash log;
    W 10/13/10 10:49:40 00274 chassis: (7F) Ports B: Blade Crash detected - Available
    I 10/13/10 10:49:45 00375 chassis: Slot B Downloading
    I 10/13/10 10:49:47 00376 chassis: Slot B Download Complete
    W 10/13/10 10:49:55 00274 chassis: Slot B Software exception at bttfSlaveUpdate. c:374 -- in 'nic82566dm', task ID = 0x61e86c0 -> Still stuck!
    I 10/13/10 10:50:05 00422 chassis: Slot B Ready
    Dont care about the module A-B id. Because When I got firsh crash, then I had changed the device port from A ports to B ports.
    Do you have any related issues?
    Regards.
  • 2.  RE: HP 8206zl Module crashed
    Posted Oct 17, 2010 01:31 AM
    1st try to upgrade to the latest firmware available and check, it's K.14.65
