Comware
  • 1.  HP A5120-24G Switch Application program does not exist
    Posted Jul 16, 2024 12:41 PM
  • 2.  RE: HP A5120-24G Switch Application program does not exist
    Posted Sep 11, 2024 10:56 AM
    I also can't find the bootroom for my equipment, A5120-SI (JE072A).
  • 3.  RE: HP A5120-24G Switch Application program does not exist
    Posted Sep 12, 2024 03:03 AM
    You can find FW files at networkingsupport.hpe.com  portal. You need to have a HPE Passport account onboarded to the portal and have a valid support contract or warranty for the switch to access firmware.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 4.  RE: HP A5120-24G Switch Application program does not exist
    Posted Sep 12, 2024 09:41 AM
    I managed to download the Firmware, but it didn't work, it gives an invalid warning something like this.
    Switch
    "H3C Comware Platform Software
    Comware Software, Version 5.20, Release 1513P84
    Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
    H3C S5120-52P-SI uptime is 0 week, 0 day, 1 hour, 36 minutes
    H3C S5120-52P-SI
    128M    bytes DRAM
    128M    bytes Nand Flash Memory
    Config Register points to Nand Flash
    Hardware Version is REV.B
    CPLD Version is 002
    Bootrom Version is 169
    [SubSlot 0] 48GE+4SFP Hardware Version is REV.B"
    Firmwares That Didn't Work Version:
    5120.SI_5.20.R1516P02 and 5120SI_5.20.R1519P06
  • 5.  RE: HP A5120-24G Switch Application program does not exist
    Posted Sep 12, 2024 10:37 AM
    Just a stupid question. Did you check release notes if PN of your switch is listed on supported list?
    Can you post "display version" and "display boot" and "display device manuinfo"?
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
