Comware
  • 1.  HP a5500 static routing
    Posted Nov 14, 2023 05:52 PM
    Good day to all!!
    I have HP A5500  (interface vlan1 10.193.197.232 255.255.255.0 ) connected to sonicwall router ( 10.193.197.250 255.255.255.0 ) .
    I have terminal ip : 10.193.197.4 , 255.25..255.0 gateway : 10.193.197.232 , with this set up I could not route my terminal to my sonicwall.
    How could I add static route on my HP switch to my sonicwall router.
  • 2.  RE: HP a5500 static routing
    Posted Nov 15, 2023 03:11 AM
    Hi, all three IP addresses are in the same subnet. There is no routing required. You need to test that the ports connecting to all devices are in the same VLAN. Check that the MAC address table for all three has the right entries.
    If you are testing by pinging, be aware most firewalls don't permit being pinged or web interface accessed unless specifically configured.
