Network Management
  • 1.  HP Aruba 2930f 50 and 52 SFP+ Ports do not work with Dac Cable.
    Posted Sep 06, 2023 10:47 AM
    Hello, I am trying to set up HP Aruba 2930F switch from scratch. However, I noticed some things while setting it up. When I make a connection between the server with the dac cable to the 4 SFP+ ports, especially to the 50 port, the ethernet status drops down after the ethernet status is up. When I connect the same dac cable to port 52, it goes up, then it goes down, then it goes up again, then it goes down again and in sh logging it says something like this;
    " FFI : Port: 52 Excessive link state transitions "
    However, when I connect with Fiber cable after installing 10Gb gbic for Normal Uplink, 50 and 52 Ports work fine. Do I need to make any settings on the Hp Aruba 2930f especially for it to work with DAC Cable. DAC Cable goes up on ports 49 and 51 without any problem.
    thankyou for support.
  • 2.  RE: HP Aruba 2930f 50 and 52 SFP+ Ports do not work with Dac Cable.
    Posted Sep 06, 2023 11:56 AM
    DAC Cable SKU?
  • 3.  RE: HP Aruba 2930f 50 and 52 SFP+ Ports do not work with Dac Cable.
    Posted Sep 06, 2023 12:45 PM
    J9283D-SN
    10G SFP+  to SFP+ DAC 3M passive
    Model : Stornet
    Transceiver Technical Information:
     Port # | Type      | Prod #     | Serial #         | Part #
     49     | SFP+SR    |     J9150D | HPS31N50126      | 1990-4391
     51     | SFP+SR    |     J9150D | HPS31N50123      | 1990-4391
     52     | SFP+SR    |     J9150D | 2101060050       | 1990-4391
  • 4.  RE: HP Aruba 2930f 50 and 52 SFP+ Ports do not work with Dac Cable.
    Posted Sep 07, 2023 02:59 AM
    Did you check that cable is also supported on server NIC?
    DAC cables are very tricky for switch to server connection. It need to be supported on both sides and that is not a given.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
