Hello everybody,
i'm trying to configure IRF with two HP FF 5700.
IRF is running, but i have a question and maybe somebody can help me.
When i try to configure the IRF i always have to configure 4 of the TenGibabit Ports on the Switch. Even if i only want to use 2 Ports.
When i shutdown e.g. Port 1/0/1 and 1/0/2 and try to add them to the IRF port i get this message:
Interfaces Ten-GigabitEthernet1/0/1 to Ten-GigabitEthernet1/0/4 belong to a port group,Please shutdown all of them before changing the working mode
So i have to shutdown all 4 ports and add them to IRF Port,then undo the shutdown. I've also tried to shutdown all 4 Ports, then add only 2 Ports to IRF and tried to get them back online, but that doesnt work either.
I have to configure 4 Ports for IRF. So, if i only want to use 2 of the TenGigabit-Ports, the other 2 TenGigabit-Ports that i have to add to IRF are useless!
I this a normal behavior or do i miss something?
Thanks in Advance!
Sebastian
