Hello Support,
When i am connecting my cisco linksys wireless router on a switch port of HP Switch 2920-48G. it is accepting only a single ip & also their is so much delay in its connectivity.
the scenarios is we have Microsoft DHCP Server Active directory running and two vlans are runing voice and data.
all ports connecting to voice vlan are properly working & getting IP of that subnet. & also user pc's connected thorugh IP phones are also working properly. but when i am connecting wirless router on that switch port it only recieves one ip. not more than.
I have also removed tagged vlan on that port which is connected to linksys wireless router.
i have check lldp and cdp is enabled on all ports. below mentioned is running config.
Startup configuration: 18
; hpStack_WB Configuration Editor; Created on release #WB.15.12.0015
; Ver #05:18.41.ff.35.0d:9b
stacking
member 1 type "J9729A" mac-address c4346b-91bc40
member 2 type "J9729A" mac-address c4346b-91dc40
exit
hostname "FF-Stack-SW"
mirror-port 2/24
trunk 1/A1,2/A1 trk1 lacp
ip default-gateway 192.X.X.X
snmp-server community "public" unrestricted
oobm
ip address dhcp-bootp
member 1
exit
member 2
exit
exit
vlan 1
name "DEFAULT_VLAN"
no untagged 1/1-1/36,2/1-2/36
untagged 1/37-1/48,1/A2,1/B1-1/B2,2/37-2/48,2/A2,2/B1-2/B2,Trk1
exit
vlan 144
name "MgmtVlan"
tagged Trk1
ip address 192.168.144.8 255.255.255.0
exit
vlan 145
name "User"
tagged Trk1
no ip address
exit
vlan 147
name "Voice"
tagged 1/1-1/6,1/8-1/36,2/1-2/36,Trk1
no ip address
voice
exit
spanning-tree
spanning-tree Trk1 priority 4
spanning-tree mode rapid-pvst
spanning-tree vlan 1 priority 15
spanning-tree vlan 144 priority 15
spanning-tree vlan 145 priority 15
spanning-tree vlan 147 priority 15
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
snmp-server 2 snmp-server 2
Stack-SW#
Stack-SW#
ip
ip-recv-mac-address
ipv6
Please suggest in which portion need to checked.
Shoaib
