Network Management
HP IMC Monitor Temperature?
  • 1.  HP IMC Monitor Temperature?
    Posted Jun 04, 2014 07:58 AM
    I am currently trying to get HP IMC 7 to monitor the temperature of HP 5412zl switches and perhaps some 5920-AF switches after that.
    The “#show system temperature” command is available on the cli, so in theory I should be able to find some MIB and OID details, but I am struggling. It is those – among other – details that I need to fill in the “create custom index” screen; of which I have attached a screenshot.
    Has anybody set HP IMC to monitor the temperature of HP switches? If so, any help and advice would be appreciated.
    Thanks in advance!
    D
  • 2.  RE: HP IMC Monitor Temperature?
    Posted Jun 17, 2014 04:24 PM
    With IMC 7.0 E0202 and ProCurve Provision switches running newer K.15.xx branches of software, I do not believe it would be necessary to create a Custom Index.
    I have attached an example using Performance Management in IMC with a ProCurve 8212 to select Temperature Monitors.
    Hope it helps!
