  • 1.  HP MSM460 SSID Broadcasting
    Posted Jul 27, 2023 11:50 AM
    I have a HP 850 wifi controller in which I am adding an access point HP MSM460, this access point has joined the cluster but it is not broadcasting SSID.
    Thanks in advance...
    Hemant Soni
  • 2.  RE: HP MSM460 SSID Broadcasting
    Posted Jul 28, 2023 09:26 AM
    Please note that these models are out of support for a long time. It's very likely that there are security vulnerabilities and missing bugfixes and optimizations.
    I'm personally not familiar with the MSM series.
  • 3.  RE: HP MSM460 SSID Broadcasting
    Posted Jul 29, 2023 06:46 AM
    Do you have enough licenses registered on the controller?
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
  • 4.  RE: HP MSM460 SSID Broadcasting
    Posted Jul 30, 2023 04:53 PM
    Hi Hemant,
    • Are all APs synchronised in the GUI?
    • Did you check the VSC configuration and inherited configurations?
    • How many access points and licenses are active?
    • End-of-Sales 31-12-2016 End-of-Support 31-12-2021.
    Maybe its time to replace this old-fashioned hardware for some nice Aruba access points.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
