Wired Intelligent Edge
HP Procurve 2510 Switch
  • 1.  HP Procurve 2510 Switch
    Posted Mar 13, 2017 07:53 AM
    I have a 2510 switch that ping and traceroute is blocked on. (I need to be able to get a response from the switch on both these commands.) How do I turn them on?
    I was going to use "ip icmp echo broadcast-request" for ping. Found out my switch does not have the "icmp".
  • 2.  RE: HP Procurve 2510 Switch
    Posted Mar 13, 2017 09:04 AM
    ICMP answers are enabled by default, but I'm not quite sure what switches you have.
    Could you provide us your product number? It usually starts with a J followed by numbers.
  • 3.  RE: HP Procurve 2510 Switch
    Posted Mar 13, 2017 09:08 AM
    It is J9019B
