Wired Intelligent Edge
  • 1.  HP ProCurve 2510G-24 (J9279A) doesn't work
    Posted Apr 05, 2013 03:36 AM
    Hi everyone.  Switch doesn't work. On LEDs are on for a prolonged time. I try to reset default. How to fix it?
  • 2.  RE: HP ProCurve 2510G-24 (J9279A) doesn't work
    Posted Apr 05, 2013 04:47 AM
    You could try connecting a serial console, then power cycling it, see if you get any useful diagnostics. If you can't get anything out of that get onto HP: it's likely to be a warranty replacement.
  • 3.  RE: HP ProCurve 2510G-24 (J9279A) doesn't work
    Posted Apr 05, 2013 11:08 AM
    We had this issue when we put some Rev A GBICs in a new switch.  Do you have any GBICs in the switch?
  • 4.  RE: HP ProCurve 2510G-24 (J9279A) doesn't work
    Posted Apr 05, 2013 11:28 AM
    Everythink is ok. I connected via serial console and boot second image. cli> jump 2. Thanks a lot.
