Wired Intelligent Edge
HP ProCurve 5400 web console issue
  • 1.  HP ProCurve 5400 web console issue
    Posted Nov 23, 2010 08:55 PM
    Hi All,
    Has anybody had issues with logging into the HP 5400 series switches via the web console?
    We upgraded all of our HP 5400 switch firmware from K.14.41 to K.14.60 and as a result we now can no longer web console into any of our HP 5400 switches from any of the workstations/servers previously used!
    When we try to web console into a switch from any previously used server/workstation prior to the firmware update, we get stuck on the login screen which will take credentials but then keeps jumping back to the login screen.  We now only have one server which will let us login to our HP 5400 switches!
    This same issue also occurs in HP Procurve Manager. We can't use Live View on our HP 5400 switches but we can use Live View on our newly purchased HP 2800 switches!? We can also web console into the new HP 2800 switches OK but they have different firmware (N.11.15) and have no security set yet.
    It seems to be some kind of Java issue and so far we have uninstalled and reinstalled both Java and IE8, cleared the IE8 and Java cookies and updated the firmware to K.14.65 without success.
    We are at a loss with this now.
    Any ideas would be most appreciated
    Trevor.
  • 2.  RE: HP ProCurve 5400 web console issue
    Posted Nov 24, 2010 05:14 AM
    Regarding Web Management.
    Have you try to disbale then enable the webmanagement ?
    Are you working with SSL (crypto cert) webmanagement ? If yes, have you try to regenerate it or suppress then create it agan ?
    5400 (2810 is a little bit different)
    web-management
    web-management plaintext
    If SSL :
    crypto key generate cert 1024
    crypto host-cert generate self-signed satart-date end-date xxx_LAN SI xxx city region fr
    web-management ssl
    Regarding PCM, what is the version ? Are you up-to-date ? PCM 2.3/3.x correctly manage these switches with the latest auto-update.
    http://h10144.www1.hp.com/customercare/support/software/network_management.htm
    We have already encountered partial or complete liveview information relevant to firmware or PCM bugs.
    Also the latest version for 2810-xxG is N.11.25 :http://h10144.www1.hp.com/customercare/support/software/summarypages/n-j9021-c.htm
    For your information 2810-xxG are replaced by E-Series 2910al-xxG (firmware W.14.xx based on K.14.xx 5400 branch of code).
    Otherwise you should open a case, sorry.
    Regards.
  • 3.  RE: HP ProCurve 5400 web console issue
    Posted Dec 20, 2010 05:29 AM
    i got the same issue with two different 5412zl Switches. It seems to be a general problem.
    If you go directly to https://ipaddress/configuration/device_view.html (or device_viewf.html) it is working on every switch except for the 5400zl.
    Did anybody found a solution?
    regards
    SVEY
  • 4.  RE: HP ProCurve 5400 web console issue
    Posted Dec 21, 2010 04:59 AM
    It works fine for me but with a different URL path running K.15. code.
    ProCurve Switch 5406zl(J8697A)
    K.15.02.0006, ROM K.15.10
    http://10.91.100.56/html/nhome.html
    Bye.
  • 5.  RE: HP ProCurve 5400 web console issue
    Posted Mar 15, 2011 10:53 AM
    Am also having the issue on K.15.02.
    i created the self signed cert, disabled / enabled web management ssl
    reset the manager and operator passwords
    and fail to logon with error message invalid user name/password  on web-ui session
  • 6.  RE: HP ProCurve 5400 web console issue
    Posted Mar 15, 2011 06:47 PM
    I finally fixed this issue by upgrading the 5400zl switch firmware from K.14.65 up to K.15.02.0005. This update seems to do away with the flawed Java authentication that was causing our login issues.
  • 7.  RE: HP ProCurve 5400 web console issue
    Posted Mar 16, 2011 07:53 AM
    so have any of you had login issues with the k15.02.0005 from cli(ssh) or console connection. I receive a half login screen and nothing else I cannot seem to enter my credentials and this is the second switch I am having a similar issue with.
    Any suggestions ?
  • 8.  RE: HP ProCurve 5400 web console issue
    Posted Jun 15, 2011 08:14 AM
    i'm currently testing with a 5412zl and Version K.15.04.0003.
    I still have the issue that the Live View through PCM+ is not working. (PCM+ 3.20.1741)
    The Live View of my 5406zl is working fine.
    Any new ideas?
    regards
    SVEY
  • 9.  RE: HP ProCurve 5400 web console issue
    Posted Jun 15, 2011 09:23 AM
    I'm actually waiting for the fix, it should be available in a couple of weeks. I can't tell you if this will be a PCM fix or a K.15 product fix, i wish it will be a PCM fix ...
    Bye.
  • 10.  RE: HP ProCurve 5400 web console issue
    Posted Jun 28, 2011 04:52 AM
    The fix is available and working in the latest release K.15.05.0002.
    Bye.
  • 11.  RE: HP ProCurve 5400 web console issue
    Posted Feb 01, 2012 01:26 PM
    At K.14.65, ROM K.12.21 we could webview into our 10 zl switches
    We upgraded to K.14.84, ROM K.12.22, and still could webview
    We also had one switch upgraded to K.15.03.005 (don't like the interface, will avoid)
    After the upgrade on 9/7/11 we started having some serious application communications delays/problems with out "Showcase" application.
    After much application/server troubleshooting/frustration we finally decided to reverse the network upgrade.
    So I downgraded ALL 10 zl switches back to K.14.65 and the problem went away?!?
    So we are stuck at K.14.65, and like everyone else can no longer webview.
  • 12.  RE: HP ProCurve 5400 web console issue
    Posted Feb 08, 2012 03:55 AM
    For your information, i'm a partner we have had to wait until K.15.06.0009 or K.15.07.xxxx to upgrade our customers and obtain a stable situation regarding performwance, stability (dynamic routing, multicats, nlb, etc.).
    Bye.
  • 13.  RE: HP ProCurve 5400 web console issue
    Posted Mar 10, 2012 08:56 PM
    Same as your problem, my 5406zl I also stagnated in the webgui login ..
    My 5406zl initial firmware is k.14.34 I've tried to upgrade to K.15.02.0005 I even try to upgrade to K_15_06_0008 but has not been solved
    If anyone has successfully
  • 14.  RE: HP ProCurve 5400 web console issue
    Posted Apr 13, 2012 11:46 AM
    We had the same problem as well with the 15.06.0008 version we just put on for a new installation. The web interface was working prior with 15.02.0005, but not after. We would just get a login screen and entering the user name/pw wouldn't work. Found out from poking around the CLI that apparently the user name is reset to blank after the update. I got around the issue by leaving the user name blank and entering the management password and got into the web interface fine. From there, you can set a user name/pwd again for management and operator levels.
