Wired Intelligent Edge
  • 1.  HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 25, 2016 08:38 AM
    Dear All
    Requesting your help to find Latest firmware of  HP J9477A Switch 8206zl. I couldnt find the firmware of this switch from the following link.  Current version is K.15.12.0012
    https://h10145.www1.hp.com/downloads/ProductsList.aspx?lang=&cc=&prodSeriesId=
    your help with this regard will be highly appericated
  • 2.  RE: HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 25, 2016 09:12 AM
    Have a look here instead.
    Once into "Download options" you will be able to find what you're looking for: the HP ProCurve 8200 zl Switch Series, in particular the 8206 zl unit (J9475A, the J9477A is the Chassis product number), has this software page.
    The K.15.12.0012 is quite old (October 2013) and development was stopped on May 2015 with its latest release K.15.12.0016...that's all for the K.15.12 software branch.
    Actually one of the current available releases (there are still two branches updated for maintenance) is the K.15.18.0013 (September 2016) of the K.15.18 software branch.
    Always read the relevant Release Notes before attempting an upgrade (to be informed about update best practices, update guidelines and update restrictions <-- especially about BootROM interim/intermediate update step required before going to the latest because you're running a quite old K.15.12 software version).
  • 3.  RE: HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 26, 2016 05:35 AM
    As per My Understanding, if this is the software I need and my Bootrom version is
    Boot ROM Version : K.15.30  , what should i do.? Should i update directly to K.15.18.0013 ?
  • 4.  RE: HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 26, 2016 05:44 AM
    Please provide the output of show version and show flash commands.
    It all depends on which Software image (and, as a consequence, which related BootROM version) your switch is currently running on.
    If you read the K.15.18.0013 Release Notes document , at page 38/39 you will be able to find this schema:
    so if your Switch software isn't between K.15.15.xxxx and K.15.18.xxxx (and you wrote you have an old K.15.12.0012 in your very first post) then you probably need to update your Switch software first to an intermediate version before performing the latest update step to the latest K.15.18.0013 software version, the intermediate version I mean (that's what is reported above) should be the K15.15.0014...it will automatically provide the BootROM version K.15.30 required.
  • 5.  RE: HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 26, 2016 05:55 AM
    HI
    this is show version and show flash command
  • 6.  RE: HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 26, 2016 06:01 AM
    OK, since the BootROM is already at K.15.30 you are free to update directly into the latest K.15.18.0013 (MM redudancy considerations apart).
  • 7.  RE: HP Procurve HP J9477A Switch 8206zl Firmware
    Posted Dec 27, 2016 03:14 AM
    Thanks A lot.
    I have updated the core switch  to latest firmware  atest K.15.18.0013 successfully.
