CX configuration example for a routed interface:
interface 1/1/34
no shutdown
mtu 9198
ip mtu 9198
ip address 172.20.16.2/32
For non-routing L2 and separate VLAN interface:
interface 1/1/12
no shutdown
no routing
mtu 9198
interface vlan 2122
description voip
ip mtu 9198
ip address 10.9.22.3/24
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Mar 21, 2025 03:32 AM
Subject: HP ProCurve to ArubaOS-CX Jumbo Frames configuration
the recommended Jumbo frame MTU setting on CX switches is 9198 that you need to set both on L3 (IP) and L2 MTU
Original Message:
Sent: Mar 19, 2025 05:26 PM
Our existing core switch is an HP Procurve 5400zl (j8697a). We have VMware hosts that connect to an iSCSI appliance. The hosts and the storage appliance use jumbo frames, as well as bonded ethernet connections. We want to move the connections from D7 and D8 on the ProCurve to ports 1/4/1 and 1/5/1 on an Aruba 6405.
As configured on the Procurve, we have the following configuration:
Old Switch (swflfllhost01)#
jumbo ip-mtu 9000
trunk D7-D8 trk11 trunk
interface D7
name "iSCSI vlan"
speed-duplex auto-10g
exit
interface D8
name "iSCSI vlan"
exit
vlan 192
name "VLAN192"
untagged D1-D6,Trk11
ip address 192.168.110.1 255.255.255.0
jumbo
exit
Will the above commands translate to the following commands for the Aruba, or are there any other commands we need add other commands, to account for the ethernet bonding and jumbo frames between the old and the new switch?
New Switch (swflfllcore01)#
interface vlan 192
ip address 192.168.110.1/24
ip mtu 9000
exit
interface 1/4/1
description NatBevFLLEsxi3-Slot1Port0
no shutdown
mtu 9000
lag 1
exit
interface 1/5/1
description NatBevFLLEsxi3-Slot2Port0
no shutdown
mtu 9000
lag 1
exit
interface lag 1
description NatBevFLLEsxi3-iSCSI
no shutdown
no routing
vlan trunk native 192
vlan trunk allowed all
exit
