Sure, here you go:
enas@Enas-WorkStation:~$ sudo grep WARN /var/log/sdn/virgo/logs/log.log
[2017-01-24 15:41:43.522] WARN system-artifacts org.apache.catalina.core.StandardHost Using an empty string for appBase on host [localhost] will set it to CATALINA_BASE, which is a bad idea
[2017-01-24 15:41:44.959] WARN system-artifacts com.hazelcast.osgi.OSGiScriptEngineManager Found ScriptEngineFactory candidate for com.sun.script.javascript.RhinoScriptEngineFactory, but cannot load class! -> org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.sun.script.javascript.RhinoScriptEngineFactory in KernelBundleClassLoader: [bundle=com.hazelcast_3.3.4]
[2017-01-24 15:41:48.306] WARN t Resolve Thread (Bundle 81) net.sf.ehcache.config.ConfigurationFactory No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/opt/sdn/virgo/repository/ext/ehcache-2.7.4.jar!/ehcache-failsafe.xml
[2017-01-24 15:41:53.485] WARN TaskExecSched-2-thread-1 hp.keystone Get revoked tokens failed.
[2017-01-24 15:42:13.392] WARN TaskExecSched-2-thread-2 hp.sdn.db Unable to establish connection to Cassandra DB
[2017-01-25 10:38:27.226] WARN system-artifacts org.apache.catalina.core.StandardHost Using an empty string for appBase on host [localhost] will set it to CATALINA_BASE, which is a bad idea
[2017-01-25 10:38:28.861] WARN system-artifacts com.hazelcast.osgi.OSGiScriptEngineManager Found ScriptEngineFactory candidate for com.sun.script.javascript.RhinoScriptEngineFactory, but cannot load class! -> org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.sun.script.javascript.RhinoScriptEngineFactory in KernelBundleClassLoader: [bundle=com.hazelcast_3.3.4]
[2017-01-25 10:38:32.437] WARN t Resolve Thread (Bundle 81) net.sf.ehcache.config.ConfigurationFactory No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/opt/sdn/virgo/repository/ext/ehcache-2.7.4.jar!/ehcache-failsafe.xml
[2017-01-25 10:38:37.619] WARN TaskExecSched-2-thread-1 hp.keystone Get revoked tokens failed.
[2017-01-25 10:38:56.376] WARN TaskExecSched-2-thread-1 hp.sdn.db Unable to establish connection to Cassandra DB
[2017-01-25 16:45:25.639] WARN system-artifacts org.apache.catalina.core.StandardHost Using an empty string for appBase on host [localhost] will set it to CATALINA_BASE, which is a bad idea
[2017-01-25 16:45:27.339] WARN system-artifacts com.hazelcast.osgi.OSGiScriptEngineManager Found ScriptEngineFactory candidate for com.sun.script.javascript.RhinoScriptEngineFactory, but cannot load class! -> org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.sun.script.javascript.RhinoScriptEngineFactory in KernelBundleClassLoader: [bundle=com.hazelcast_3.3.4]
[2017-01-25 16:45:30.991] WARN t Resolve Thread (Bundle 81) net.sf.ehcache.config.ConfigurationFactory No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/opt/sdn/virgo/repository/ext/ehcache-2.7.4.jar!/ehcache-failsafe.xml
[2017-01-25 16:45:36.197] WARN TaskExecSched-2-thread-1 hp.keystone Get revoked tokens failed.
[2017-01-25 17:07:00.525] WARN system-artifacts org.apache.catalina.core.StandardHost Using an empty string for appBase on host [localhost] will set it to CATALINA_BASE, which is a bad idea
[2017-01-25 17:07:01.991] WARN system-artifacts com.hazelcast.osgi.OSGiScriptEngineManager Found ScriptEngineFactory candidate for com.sun.script.javascript.RhinoScriptEngineFactory, but cannot load class! -> org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.sun.script.javascript.RhinoScriptEngineFactory in KernelBundleClassLoader: [bundle=com.hazelcast_3.3.4]
[2017-01-25 17:07:05.297] WARN t Resolve Thread (Bundle 81) net.sf.ehcache.config.ConfigurationFactory No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/opt/sdn/virgo/repository/ext/ehcache-2.7.4.jar!/ehcache-failsafe.xml
[2017-01-25 17:07:10.798] WARN TaskExecSched-2-thread-1 hp.keystone Get revoked tokens failed.
[2017-01-25 17:09:54.152] WARN system-artifacts org.apache.catalina.core.StandardHost Using an empty string for appBase on host [localhost] will set it to CATALINA_BASE, which is a bad idea
[2017-01-25 17:09:55.618] WARN system-artifacts com.hazelcast.osgi.OSGiScriptEngineManager Found ScriptEngineFactory candidate for com.sun.script.javascript.RhinoScriptEngineFactory, but cannot load class! -> org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.sun.script.javascript.RhinoScriptEngineFactory in KernelBundleClassLoader: [bundle=com.hazelcast_3.3.4]
[2017-01-25 17:09:58.927] WARN t Resolve Thread (Bundle 81) net.sf.ehcache.config.ConfigurationFactory No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/opt/sdn/virgo/repository/ext/ehcache-2.7.4.jar!/ehcache-failsafe.xml
[2017-01-25 17:10:04.376] WARN TaskExecSched-2-thread-1 hp.keystone Get revoked tokens failed.
[2017-01-25 17:10:22.973] WARN TaskExecSched-2-thread-2 hp.sdn.db Unable to establish connection to Cassandra DB
[2017-01-26 09:52:24.772] WARN RxQPool-7-thread-3 hp.of.ctl com.hp.sdn.disco.of.device.impl.OfPortStatusListener: interrupted exception: java.lang.InterruptedException
[2017-01-26 09:52:24.774] WARN DpQPool-8-thread-4 hp.of.ctl com.hp.sdn.disco.of.device.impl.OfApDeviceDiscovery$ApDpListener: interrupted exception: java.lang.InterruptedException
[2017-01-26 09:52:25.003] WARN DpQPool-8-thread-2 hp.of.ctl com.hp.sdn.dvc.impl.FacetComponent$DeviceCleaner: interrupted exception: java.lang.InterruptedException
[2017-01-26 09:54:12.662] WARN system-artifacts org.apache.catalina.core.StandardHost Using an empty string for appBase on host [localhost] will set it to CATALINA_BASE, which is a bad idea
[2017-01-26 09:54:14.159] WARN system-artifacts com.hazelcast.osgi.OSGiScriptEngineManager Found ScriptEngineFactory candidate for com.sun.script.javascript.RhinoScriptEngineFactory, but cannot load class! -> org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: com.sun.script.javascript.RhinoScriptEngineFactory in KernelBundleClassLoader: [bundle=com.hazelcast_3.3.4]
[2017-01-26 09:54:17.462] WARN t Resolve Thread (Bundle 81) net.sf.ehcache.config.ConfigurationFactory No configuration found. Configuring ehcache from ehcache-failsafe.xml found in the classpath: jar:file:/opt/sdn/virgo/repository/ext/ehcache-2.7.4.jar!/ehcache-failsafe.xml
[2017-01-26 09:54:22.613] WARN TaskExecSched-2-thread-1 hp.keystone Get revoked tokens failed.
enas@Enas-WorkStation:~$ clear
enas@Enas-WorkStation:~$ sudo grep ERROR /var/log/sdn/virgo/logs/log.log
[2017-01-25 10:39:41.783] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.785] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.811] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.813] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.814] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.815] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.817] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.818] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.936] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.937] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.938] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 10:39:41.940] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.366] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.370] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.427] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.429] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.431] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.432] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.433] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.434] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.549] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.550] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.551] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 16:51:37.552] ERROR GiLogServiceListener@840727c org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:07:00.661] ERROR system-artifacts org.apache.coyote.http11.Http11Protocol Failed to initialize end point associated with ProtocolHandler ["http-bio-8080"] java.net.BindException: Address already in use <null>:8080
[2017-01-25 17:07:00.664] ERROR system-artifacts org.apache.catalina.core.StandardService Failed to initialize connector [Connector[HTTP/1.1-8080]] org.apache.catalina.LifecycleException: Failed to initialize component [Connector[HTTP/1.1-8080]]
[2017-01-25 17:09:41.733] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.734] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.783] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.785] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.789] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.790] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.792] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.793] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.910] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.912] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.913] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-25 17:09:41.914] ERROR iLogServiceListener@1cbc5000 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.121] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle com.hp.sdn.sdn-common-bl_2.7.18, [SCR] Error while attempting to deactivate instance of component Component[
[2017-01-26 09:52:25.124] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Error while attempting to deactivate instance of component Component[
[2017-01-26 09:52:25.128] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.130] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.185] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.186] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.187] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.188] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.190] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.191] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.308] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.309] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.310] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
[2017-01-26 09:52:25.312] ERROR iLogServiceListener@5891cc92 org.osgi.service.log.LogService Bundle org.eclipse.equinox.ds_1.4.0.v20120112-1400, [SCR] Unexpected exception occurred! java.lang.IllegalStateException: BundleContext is no longer valid
Enas
