Comware
  • 1.  hp1910-8g vlan help
    Posted Dec 11, 2014 07:12 AM
    hi i need help on comunication between vlan 1 and vlan 2
    My startup.cfg is
    version 5.20, Release 1513P89
    sysname HP
    dhcp relay server-group 1 ip 192.168.6.1
    domain default enable system
    ip ttl-expires enable
    password-recovery enable
    acl number 3001
    rule 10 permit ip
    vlan 1
    description VLAN 1
    vlan 2
    description VLAN 2
    vlan 3
    description VLAN 3
    domain system
    access-limit disable
    state active
    idle-cut disable
    self-service-url disable
    user-group system
    local-user admin
    authorization-attribute level 3
    service-type ssh telnet terminal
    service-type web
    stp mode rstp
    stp enable
    interface NULL0
    interface Vlan-interface1
    ip address 192.168.6.253 255.255.255.0
    interface Vlan-interface2
    ip address 192.168.220.0 255.255.255.128
    dhcp select relay
    dhcp relay server-select 1
    interface GigabitEthernet1/0/1
    stp edged-port enable
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    port link-type hybrid
    undo port hybrid vlan 1
    port hybrid vlan 2 tagged
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
    interface GigabitEthernet1/0/8
    interface GigabitEthernet1/0/9
    ip route-static 0.0.0.0 0.0.0.0 Vlan-interface1 192.168.6.1
    snmp-agent
    snmp-agent local-engineid 8000000B037848590A3A6D
    snmp-agent sys-info contact hw
    snmp-agent sys-info location slv
    snmp-agent sys-info version v3
    ssh server enable
    user-interface aux 0
    authentication-mode scheme
    user-interface vty 0 15
    return
    P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to  Web and Unmanaged. - Hp Forum Moderator
  • 2.  RE: hp1910-8g vlan help
    Posted Dec 11, 2014 07:33 PM
    Can your devices ping their default gateway?
    WHy are you using "hybrid" VLAN trunk ports?
    Why do you have VLAN2 tagged on two ports?
