Wired Intelligent Edge
HP/Aruba Switch firmware versions
  • 1.  HP/Aruba Switch firmware versions
    Posted Dec 06, 2018 11:40 AM
    I want to update firmware to one shown as approved for Airwave.   We have the 2920s and a 3800.  I was looking at the firmwares for the 2920 and there a SEVERAL for Current Release and I don't understand the version number format.  Our current version is.:
    WB.16.05.004
    The issue is the there are 6 firmwares released across 3 days in December of 2018.
    WC.16.02.0026
    WB16.08.0001
    WB.16.07.0003
    WB.16.06.0009
    WB.16.05.0012
    WB.16.02.0026
    The approved version is WB16.06.0006.   Just not sure what all the variations mean.  I assume going from WB.16.05 to 16.06 would be fine.  Are they just different branches?
    Or should I move to WB.16.08.0001 which has WB.16.06.0006 in it's release history?
  • 2.  RE: HP/Aruba Switch firmware versions
    Posted Jan 10, 2019 07:50 PM
    Hi There
    Did you get a respone to your query??
    Because i was wondering the same thing
    Cheers
