Comware
HPE 1910-8G automatic config backup
  • 1.  HPE 1910-8G automatic config backup
    Posted Jul 11, 2022 09:35 PM
    Hi everyone,
    I've got these 1910-8G switches (lots of them) and I would like to backup their config automatically on a regular basis, is there a way to do this? Their CLI seems to be quite limited and I doubt they have a rest api or anything like that... I potentially could use curl but that web captcha drives me nuts...
    Is there a firmware upgrade (currently on 5.20 Release 1519P06) or anything that may improve usability of these switches?
    Thanks.
  • 2.  RE: HPE 1910-8G automatic config backup
    Posted Jul 26, 2022 10:48 PM
    I did this years ago using kiwi cat tools through cli - i had to use the "secret" command line tools:
    1.  connect to switch through ssh or (gasp!) telnet.
    2.  To enable the secret command line commands: you have to type the following command: _cmdline-mode on
    3.  And press enter. You will get a question. Answer with Yes.
    4.  If you don't have a password you will get a popup notification on the CLI Type the code 512900
    https://freddejonge.nl/hp-v1910-secret-commando-list-how-to-enable-it/
