Comware
  • 1.  HPE 1920S maximum L3 vlan interface
    Posted Sep 14, 2020 12:07 PM
    What is the Maximum Limit of L3 VLAN interface on 1920S Switch
  • 2.  RE: HPE 1920S maximum L3 vlan interface
    Posted Sep 14, 2020 12:09 PM
    You can create upto 256 VLAN's.
    Can you please share product number 'JXXXXX' of the device so will check and confirm the interface vlan(SVI) limitations?
    Refer quick specs guide.
    https://h20195.www2.hpe.com/v2/GetDocument.aspx?docname=a00001630enw
    Thanks!
  • 3.  RE: HPE 1920S maximum L3 vlan interface
    Posted Sep 14, 2020 09:42 PM
    If your device lies into below models then it supports 8 virtual VLAN interfaces if I am not wrong.
    Models
    HPE OfficeConnect 1920 8G Switch JG920A
    HPE OfficeConnect 1920 8G PoE+ (65W) Switch JG921A
    HPE OfficeConnect 1920 8G PoE+ (180W) Switch JG922A
    HPE OfficeConnect 1920 16G Switch JG923A
    HPE OfficeConnect 1920 24G Switch JG924A
    HPE OfficeConnect 1920 24G PoE+ (180W) Switch JG925A
    HPE OfficeConnect 1920 24G PoE+ (370W) Switch JG926A
    HPE OfficeConnect 1920 48G Switch JG927A
    HPE OfficeConnect 1920 48G PoE+ (370W) Switch JG928A
    and if your devices lies under below models then it support 16SVI's  this is what my colleague @Ivan_B said.
    Models
    HPE OfficeConnect 1920S 8G Switch JL380A
    HPE OfficeConnect 1920S 24G 2SFP Switch JL381A
    HPE OfficeConnect 1920S 48G 4SFP Switch JL382A
    HPE OfficeConnect 1920S 8G PPoE+ 65W Switch JL383A
    HPE OfficeConnect 1920S 24G 2SFP PPoE+ 185W Switch JL384A
    HPE OfficeConnect 1920S 24G 2SFP PoE+ 370W Switch JL385A
    HPE OfficeConnect 1920S 48G 4SFP PPoE+ 370W Switch JL386A
    Thanks!
  • 4.  RE: HPE 1920S maximum L3 vlan interface
    Posted Sep 14, 2020 12:26 PM
    Hi @dmchandrasinghe !
    The maximum number of SVIs configured simultaneously is 16. These numbers are valid for all models of 1920S.
    Hope this helps!
