Comware
  • 1.  HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 11:27 AM
    What is Maximum Limit of L3 Vlan Interfaces on the 1920S Switch
  • 2.  RE: HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 12:07 PM
    You can create upto 256 VLAN's.
    Can you please share product number 'JXXXXX' of the device so will check and confirm the itnerface vlan limitations?
    Refer quick specs guide.
    https://h20195.www2.hpe.com/v2/GetDocument.aspx?docname=a00001630enw
    Thanks!
  • 3.  RE: HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 12:12 PM
    I am asking how many L3 VLAN interface count. 1950 also support 8 Nos of L3 Vlan interfaces in access models
  • 4.  RE: HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 12:14 PM
    Hi @dmchandrasinghe !
    Colleague @akg7 is right, you can configure up to 256 VLANs on 1920S series switches.
    However, I think your question was about Vlan-interfaces (SVI). The maximum number of SVIs configured simultaneously is 16. These numbers are valid for all models of 1920S.
    Hope this helps!
  • 5.  RE: HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 12:29 PM
    so that means, I can assign 16 IP addresses to each interface and enable inter vlan routing between each other.
    I have a doubt since 1950 have an 8 l3 interface limitation.
  • 6.  RE: HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 12:38 PM
    If your device lies into below models then it supports 8 virtual VLAN interfaces if I am not wrong.
    Models
    HPE OfficeConnect 1920 8G Switch JG920A
    HPE OfficeConnect 1920 8G PoE+ (65W) Switch JG921A
    HPE OfficeConnect 1920 8G PoE+ (180W) Switch JG922A
    HPE OfficeConnect 1920 16G Switch JG923A
    HPE OfficeConnect 1920 24G Switch JG924A
    HPE OfficeConnect 1920 24G PoE+ (180W) Switch JG925A
    HPE OfficeConnect 1920 24G PoE+ (370W) Switch JG926A
    HPE OfficeConnect 1920 48G Switch JG927A
    HPE OfficeConnect 1920 48G PoE+ (370W) Switch JG928A
    and if your devices lies under below models then it support 16SVI's  this is what my colleague @Ivan_B said.
    Models
    HPE OfficeConnect 1920S 8G Switch JL380A
    HPE OfficeConnect 1920S 24G 2SFP Switch JL381A
    HPE OfficeConnect 1920S 48G 4SFP Switch JL382A
    HPE OfficeConnect 1920S 8G PPoE+ 65W Switch JL383A
    HPE OfficeConnect 1920S 24G 2SFP PPoE+ 185W Switch JL384A
    HPE OfficeConnect 1920S 24G 2SFP PoE+ 370W Switch JL385A
    HPE OfficeConnect 1920S 48G 4SFP PPoE+ 370W Switch JL386A
    Thanks!
  • 7.  RE: HPE 1920S Maximum L3 VLAN Interfaces
    Posted Sep 14, 2020 12:47 PM
    I understand your scepticism, @dmchandrasinghe and you are almost right about 8 SVIs on 1950 series, but not exactly.
    If we speak about 1950 models that have 1G ports and 10G uplinks, then you are right - 8 SVIs maximum.
    However, don't forget that 1950 series have 1950-12XGT model with 12 x 10G copper ports and 4 x 10G SFP+ ports (JH295A). That little beast supports up to 32 SVIs.
    And according the same table that provided me abovementioned numbers (internal doc, can't share it, sorry) all 1920S models support up to 16 SVIs.
    And just FYI - 1950 and 1920S are very, very different devices. 1950 runs Comware 7, 1920S runs customized Linux-based OS with GUI as the only management option. And they have very different SoCs.
