What SKU (Part Number) has this SFP Transceiver? where are you planning to use it (what Aruba Switch model?)? consider that each vendor (HP-HPE-Aruba is "one" vendor from the Switching standpoint, with some differences about options cross compatibility on DC Switch series versus Campus/Access Switch series) tends to be selective with supported options to use in their devices...so Aruba prefers (requires) Aruba, D-Link prefers (requires) D-Link...and so on.
Probably some old 3Com Switches are able to support some not-so-new HP options (SFP Transceivers)...but you should check on related Datasheets/QuickSpecs/Hardware Manuals to be sure.
