Comware
  • 1.  HPE 5130 dropping pings
    Posted Oct 21, 2019 05:14 AM
    I have a workstation and a bunch of embedded real-time systems in a private network. (I would attach an image, but I guess that is not allowed for new users.) The number of embedded devices increased, so I replaced our HP Procurve 2524 switch with a new HPE 5130-48G-PoE+-4SFP+. The workstation has IP address 192.168.1.1, and the embedded devices span a continuous range of IP addresses in the 192.168.1.0 subnet. Bridge configuration is fine for this purpose (except that I would like to be able to remotely manage the switch from the workstation), so I started testing with the switch factory settings.
    Pinging the embedded devices from the workstation with increasing packet size caused lost packets already at little over 8 kB. I enabled jumbo frames and burst mode, but these didn't have any effect. Does anyone have any ideas what might be causing this? I also seem to get ten to hundred times longer latencies in the private network than I do with the same workstation in a public network with an identical switch.
    Another question: After the tests, I enabled remote management. I can now use the management GUI, but I would rather use CLI. However, I get "Connection to 192.168.1.2 closed by remote host" as soon as SSH accepts the password. Any hints on what might still be missing from the configuration?
  • 2.  RE: HPE 5130 dropping pings
    Posted Oct 25, 2019 06:56 AM
    Are the following commands added on to the device? I've had issues with ping/traceroutes before an using these helped.
    ip unreachables enable
    ip ttl-expires enable
  • 3.  RE: HPE 5130 dropping pings
    Posted Dec 04, 2019 02:30 AM
    I'll try to address some of your points.
    Was this also an issue with the Procurve-switch, or is this a newly arisen problem (when you deployed the 5130)? Embedded devices are usualy small with close to very little CPU. Sending large frames to the CPU might not just be a good idea.
    What do mean here? Public Network vs private network. Do you mean on a network using public addressing (i.e not RFC 1918 addresses?)  Anyway. Increasing ping times when pinging "through" the switch is not related to the switch. (Switch just forwards packets)
    You need to do a few things before ssh works.
    public-key local create rsa
    line vty 0 63
     authentication-mode scheme
     protocol inbound ssh
     quit
    domain <name-of-your-domain>
     <define-your-aaa-methods> # tacacs+ / radius / local
     quit
    default domain <name-of-your-domain> enable
    Also, if your method is local, you want to create a local user for that purpose.
    local-user <local-user-name> class manage
     password hash <password-hash>
     service-type ssh
     authorization-attribute user-role network-admin #user can do anything
     quit
    Regards
