Hi @ALL,
Site 1: 5130 el with multi Vlan Setting, and Auto Voice enabled.
dhcp relay on each VLan.
MPLS------> Site 0, DHCP Server enabled
Through MPLS Nertwork to Site 0 the DHCP Discover has the Source IP from the output Interface which directs to the MPLS Network, ( we use a transfer-net)., TCPDUMP checked.
I think the source IP must be the vlan-interface IP from the relay request ist started.
But, how can I do this?
dhcp relay source-address , I know
Is there a global command, take all vlan interfaces for relay actions?
I ve 30 HPE el switches in place, but this one has always the false source.
JG937A Description HPE Comware Platform Software, Software Version 7.1.070, Release 3506P02 HPE 5130 48G PoE+ 4SFP+ EI Switch Copyright
- interface Vlan-interface1
- ip address 192.168.2.120 255.255.255.0
- interface Vlan-interface2
- ip address 10.4.1.254 255.255.255.0
- dhcp select relay
- dhcp relay server-address 10.1.254.10
- dhcp relay server-address 10.15.245.10
- dhcp relay server-address 10.0.5.30
- interface Vlan-interface11
- ip address 10.4.11.254 255.255.255.0
- dhcp select relay
- interface Vlan-interface30
- ip address 10.4.30.254 255.255.255.0
- dhcp select relay
- interface Vlan-interface40
- ip address 10.4.40.254 255.255.255.0
- dhcp select relay
- interface Vlan-interface51
- ip address 10.4.51.254 255.255.255.0
- dhcp select relay
- interface Vlan-interface65
- ip address 10.4.65.254 255.255.255.0
- dhcp select relay
- interface Vlan-interface100
- ip address 10.4.100.254 255.255.255.0
- interface Vlan-interface239
- ip address 10.4.239.254 255.255.255.0
- interface Vlan-interface250
- ip address 10.4.250.254 255.255.255.0
- dhcp select relay
- interface Vlan-interface255
- ip address 10.4.255.254 255.255.255.0
- interface Vlan-interface930
- ip address 172.30.0.30 255.255.255.248
