Wired Intelligent Edge
HPE 5130 - JG932A - Old firmware Needs firmware upgrade
  • 1.  HPE 5130 - JG932A - Old firmware Needs firmware upgrade
    Posted Jan 19, 2024 07:05 AM
    see our config tell us what is wrong, we are unable to connect to the the switch on port 24,  ip-subnet-vlan 0 ip 192.168.0.7 255.255.240.0 is this the way to give the switch a IP, so we can connect it on  access  vlan 5 and the document on the switch refer to a newer firmware.  where they use
    <switch03.aalborghus.dk>display version
    HP Comware Software, Version 7.1.045, Release 3108P03-US
    Copyright (c) 2010-2015 Hewlett-Packard Development Company, L.P.
    HP 5130-24G-4SFP+ EI Switch uptime is 0 weeks, 2 days, 9 hours, 41 minutes
    Last reboot reason : Cold reboot
    Boot image: flash:/5130ei-cmw710-boot-r3108p03-US.bin
    Boot image version: 7.1.045-US, Release 3108P03-US
      Compiled Jan 28 2015 12:51:15
    System image: flash:/5130ei-cmw710-system-r3108p03-US.bin
    System image version: 7.1.045, Release 3108P03-US
    Slot 2:
    Uptime is 0 weeks,2 days,9 hours,41 minutes
    HP 5130-24G-4SFP+ EI JG932A with 1 Processor
    BOARD TYPE:         5130-24G-4SFP+ EI
    DRAM:               1024M bytes
    FLASH:              512M bytes
    PCB 1 Version:      VER.B
    Bootrom Version:    120
    CPLD 1 Version:     002
    Release Version:    HP 5130-24G-4SFP+ EI JG932A-3108P03-US
    Patch Version  :    None
    Reboot Cause  :     ColdReboot
    [SubSlot 0] 24GE+4SFP Plus
    <switch03.aalborghus.dk>  display curen
    <switch03.aalborghus.dk>display curr
    <switch03.aalborghus.dk>display current-configuration
     version 7.1.045, Release 3108P03-US
     sysname switch03.aalborghus.dk
     clock timezone Amsterdam add 01:00:00
     clock summer-time FDT 09:54:14 March fourth Sunday 09:54:14 October fourth Sunday 01:00:00
     clock protocol ntp
     irf mac-address persistent timer
     irf auto-update enable
     undo irf link-delay
     irf member 2 priority 1
     lldp global enable
     password-recovery enable
    vlan 1
     name "DEFAULT_VLAN"
    vlan 5
     name "UNET"
    vlan 6
     name "Kontor"
    vlan 20
     name "Eksamen"
    vlan 30
     name "DMZ"
     stp global enable
    interface NULL0
    interface GigabitEthernet2/0/1
     port access vlan 5
    interface GigabitEthernet2/0/2
     port access vlan 5
    interface GigabitEthernet2/0/3
     port access vlan 5
    interface GigabitEthernet2/0/4
     port access vlan 5
    interface GigabitEthernet2/0/5
     port access vlan 5
    interface GigabitEthernet2/0/6
     port access vlan 5
    interface GigabitEthernet2/0/7
     port access vlan 5
    interface GigabitEthernet2/0/8
     port access vlan 5
    interface GigabitEthernet2/0/9
     port access vlan 5
    interface GigabitEthernet2/0/10
     port access vlan 5
    interface GigabitEthernet2/0/11
     port access vlan 5
    interface GigabitEthernet2/0/12
     port access vlan 5
    interface GigabitEthernet2/0/13
     port access vlan 5
    interface GigabitEthernet2/0/14
     port access vlan 5
    interface GigabitEthernet2/0/15
     port access vlan 5
    interface GigabitEthernet2/0/16
     port access vlan 5
    interface GigabitEthernet2/0/17
     port access vlan 5
    interface GigabitEthernet2/0/18
     port access vlan 5
    interface GigabitEthernet2/0/19
     port access vlan 5
    interface GigabitEthernet2/0/20
     port access vlan 5
    interface GigabitEthernet2/0/21
     port access vlan 5
    interface GigabitEthernet2/0/22
     port access vlan 5
    interface GigabitEthernet2/0/23
     port access vlan 5
    interface GigabitEthernet2/0/24
     port access vlan 5
    interface Ten-GigabitEthernet2/0/25
     port link-type trunk
     port trunk permit vlan 1 5 to 6 20 30
    interface Ten-GigabitEthernet2/0/26
    interface Ten-GigabitEthernet2/0/27
    interface Ten-GigabitEthernet2/0/28
     scheduler logfile size 16
    line class aux
     user-role network-admin
    line class vty
     user-role network-operator
    line aux 1
    line vty 0 15
     authentication-mode scheme
    line vty 16 63
     ssh server enable
     ntp-service enable
    radius scheme system
     user-name-format without-domain
    domain defualt
    domain system
     authentication login local
     authorization login local
     domain default enable system
    role name level-0
     description Predefined level-0 role
    role name level-1
     description Predefined level-1 role
    role name level-2
     description Predefined level-2 role
    role name level-3
     description Predefined level-3 role
    role name level-4
     description Predefined level-4 role
    role name level-5
     description Predefined level-5 role
    role name level-6
     description Predefined level-6 role
    role name level-7
     description Predefined level-7 role
    role name level-8
     description Predefined level-8 role
    role name level-9
     description Predefined level-9 role
    role name level-10
     description Predefined level-10 role
    role name level-11
     description Predefined level-11 role
    role name level-12
     description Predefined level-12 role
    role name level-13
     description Predefined level-13 role
    role name level-14
     description Predefined level-14 role
    user-group system
    local-user admin class manage
     password hash REMOVED
     service-type ftp
     service-type ssh http https
     authorization-attribute user-role network-admin
     authorization-attribute user-role network-operator
     ftp server enable
     ip http enable
     ip https enable
    return
  • 2.  RE: HPE 5130 - JG932A - Old firmware Needs firmware upgrade
    Posted Jan 19, 2024 07:22 AM
    found solution with interface vlan 5 ip adress instead thanks in advace.
