Hi Jerry.
The simple rule for IRF is, that you always connect logical port 1 on one switch to logical port 2 on another switch. If you have full ring configuration, then you can break the ring in any point you want and it will work.
In your case you want to add a new switch between switch 1 and 8. So you need to connect port 2 (FG 1/0/42) on switch 1 to port 1 (FG 9/0/41) on switch 9 and port 2 (FG 9/0/42) on switch 9 to port 1 (FG 8/0/41) on switch 8.
IRF Tech note
IRF Configuration Guide
In your case you can break the ring and add a new switch after first reboot.
Take a look to page 14 of the IRF Configuration Guide for sequence of tasks involved in adding a stack member.
This is from Tech note:
2.3.1 Joining of a Member Device
During the Stack maintenance, topology collection is performed. When a new member joins the Stack, the Stacking system may take one of the following approaches:
The newly added device was not in any other Stack before it joined this Stack. For example, you configure Stack functions on the device, power it off, connect it to the Stack using Stack cables, and power it on. In this situation, the new member will be elected as a slave.
The newly added device was in another Stack before it joined this Stack. For example, you configure Stack functions on the device, and connect it to another Stack. After that, if you want to add the device to this Stack, it is a Stack merge, that is, a process of connecting two existing Stack s together, which is not recommended. During the mergence, Stack election is held, and members of the loser side reboot and join the winner side as slaves.
If a member joins a Stack successfully, it is equal to adding an SMB and interfaces on this board for the Stacking system.
The probable reasons for a member to join a Stack can be:
• The member device is manually added into the Stack.
• The member device is recovered from a system failure or link failure, and it will join the Stack again automatically
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Feb 10, 2025 03:47 PM
Subject: HPE 5700 Add additional switch
Does this make sense?
system-view
irf member 1 renumber 9
yes
save force
quit
reboot
yes
-STOP----- (after reboot)
system-view
interface range FortyGigE9/0/41 to FortyGigE9/0/42
shutdown
quit
irf-port 9/1
port group interface FortyGigE9/0/41
quit
irf-port 9/2
port group interface FortyGigE9/0/42
quit
undo shutdown
quit
save force
irf-port-configuration active
save force
(The device reboots now automatically)
When should I connect cables?
At this time do I disconnect cables between slot 8 and slot 1 and connect cables between slot 8 and slot 9 and slot 9 and slot 1?
Do I need to do anything on Switches 8 and 1?
Original Message:
Sent: Feb 10, 2025 11:59 AM
FortyGigE7/0/42 --> FortyGigE8/0/41
FortyGigE8/0/42 --> FortyGigE1/0/41
FortyGigE1/0/42 --> FortyGigE2/0/41
Original Message:
Sent: Feb 10, 2025 10:56 AM
Hi @jerryroy1!
To play on the safe side, could you share physical topology of logical IRF ports between Slot 1 and 8, e.g. which physical ports of Slot 1 and 8 are currently connected?
Ivan Bondar
Original Message:
Sent: Feb 05, 2025 07:39 PM
Hi Anyone have an Idea? :)
Original Message:
Sent: Jan 30, 2025 05:26 PM
I want to confirm the commands I have applied to an additional switch I will add to my ring are correct, and I WILL NOT interrupt any traffic.
Existing Ring:
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
irf member 1 priority 28
irf member 2 priority 30
irf member 3 priority 26
irf member 4 priority 24
irf member 5 priority 22
irf member 6 priority 20
irf member 7 priority 18
irf member 8 priority 16
irf mode normal
lldp global enable
system-working-mode StandardBridge
password-recovery enable
irf-port 1/1
port group interface FortyGigE1/0/41
irf-port 1/2
port group interface FortyGigE1/0/42
irf-port 2/1
port group interface FortyGigE2/0/41
irf-port 2/2
port group interface FortyGigE2/0/42
irf-port 3/1
port group interface FortyGigE3/0/42
irf-port 3/2
port group interface FortyGigE3/0/41
irf-port 4/1
port group interface FortyGigE4/0/42
irf-port 4/2
port group interface FortyGigE4/0/41
irf-port 5/1
port group interface FortyGigE5/0/41
irf-port 5/2
port group interface FortyGigE5/0/42
irf-port 6/1
port group interface FortyGigE6/0/41
irf-port 6/2
port group interface FortyGigE6/0/42
irf-port 7/1
port group interface FortyGigE7/0/41
irf-port 7/2
port group interface FortyGigE7/0/42
irf-port 8/1
port group interface FortyGigE8/0/41
irf-port 8/2
port group interface FortyGigE8/0/42
stp global enable
New Ring Member connecting to switch 8 and switch 1:
undo irf link-delay
irf member 9 priority 14
irf mode normal
irf-port 9/1
irf-port 9/2
Interfaces have already been undo shut and irf-port-configuration active applied
Can I now unplug link between 1 and 8 and plug 8 into 9 and 9 into 1 without issue?
Code version on 9 is same as all others in ring.
Have I missed any commands?
